Series solution of ODE near singular points with trig
The discussion revolves around a differential equation involving trigonometric functions, specifically the equation (\sin x)y'' + xy' + (x - \frac{1}{2})y = 0. Participants are tasked with identifying regular singular points, deriving the indicial equation, and determining the form of solutions near these points.
  • Mixed
  • The original poster attempts to identify regular singular points and expresses uncertainty regarding the indicial equation and the form of solutions. They explore the limits of certain expressions to determine singular points and question the validity of their findings.
  • Some participants suggest using Taylor series expansions for \sin x and discuss the implications of these expansions on finding the indicial equation and recurrence relations.
  • Others question the necessity of normalizing terms in the Frobenius method and seek clarification on the process of deriving the indicial equation from the power series.
  • There is a discussion about the nature of singular points, with some participants questioning why x = 0 is not the only regular singular point.
The discussion is ongoing, with participants providing various insights and methods for approaching the problem. Some guidance has been offered regarding the use of Taylor series and the structure of the Frobenius method, but there remains a lack of consensus on certain aspects, particularly regarding the indicial equation and the identification of singular points.
Participants are navigating the complexities of the problem, including the behavior of the differential equation near singular points and the implications of using trigonometric functions in the context of series solutions. There is an acknowledgment of potential missing information and varying interpretations of the problem setup.
wadawalnut
Given the differential equation
[itex](\sin x)y'' + xy' + (x - \frac{1}{2})y = 0[/itex]
a) Determine all the regular singular points of the equation
b) Determine the indicial equation corresponding to each regular point
c) Determine the form of the two linearly independent solutions near each of the singular points
d) Give the behavior of all non-zero solutions as x approaches 0.
I'm mostly concerned about questions b) and c), as those are the ones that I'm stuck at.
Singular points of equations with the form [itex]b(x)y'' + p(x)y' + q(x)y = 0[/itex] occur when [itex]b(x) = 0[/itex] and [itex]\frac{(x-x_0)p(x)}{b(x)}[/itex] has a definite limit as x -> x0 and [itex]\frac{(x-x_0)^2q(x)}{b(x)}[/itex] has a definite limit as x -> x0.
Since we're looking for solutions near singular points, I am assuming we have to use the Frobenius method, as that's the only method I'm aware of for doing such a thing. So, assume [itex]y = x^r \sum_{n=0}^{\infty}a_nx^n[/itex].
So the first thing I attempted was finding the regular singular points.
Firstly, [itex]\sin x = 0[/itex] when [itex]x = \pi n, n \in Z[/itex]. So all regular singular points must be in that set.
Looking at [itex]\frac{xp(x)}{b(x)}[/itex] we get for x = 0: [itex]\frac{x^2}{\sin(x)} = x * (\frac{\sin(x)}{x})^{-1} \\[/itex] and [itex]\frac{x^2q(x)}{b(x)} = \frac{x^3}{\sin(x)} - \frac{x^2}{2\sin(x)}[/itex]. The limit of each of these is 0 because the limit as x approaches 0 of [itex]\frac{\sin(x)}{x} = 1[/itex]. So 0 looks like a regular singular point. However, for every other possible singular point ([itex]x = \pi, 2\pi, 3\pi ...[/itex]), I don't believe these limits exist, because instead of [itex]\frac{x}{sin(x)} = \frac{0}{0}[/itex] there would be a real number divided by 0. So I believe the only regular singular point is at x = 0.
Next I tried to find the indicial equation, but no matter how I try it, I get the indicial equation in terms of [itex]a_0[/itex] and [itex]a_1[/itex]. Here's my procedure:
[itex]y = x^r \sum_{n=0}^{\infty} a_nx^n = \sum_{n=0}^{\infty}a_nx^{n+r} \\[/itex]
[itex]y' = \sum_{n=0}^{\infty} a_n(n+r)x^{n+r-1} \\[/itex]
[itex]y'' = \sum_{n=0}^{\infty} a_n(n+r)(n+r-1)x^{n+r-2} \\[/itex]
So here's the differential equation in series form: [itex]\\[/itex]
[itex]\sum_{n=0}^{\infty} a_n(n+r)(n+r-1)\sin(x)x^{n+r-2} + \sum_{n=0}^{\infty} a_n(n+r)x^{n+r} + \sum_{n=0}^{\infty} a_nx^{n+r+1} - \sum_{n=0}^{\infty} \frac{a_n}{2}x^{n+r} = 0\\[/itex]
Next, I shifted the indices so all sums were in terms of [itex]x^{n+r+1} \\[/itex]
[itex]\sum_{n=-2}^{\infty} a_{n+2}(n+r+2)(n+r+1)\sin(x)x^{n+r+1} + \sum_{n=-1}^{\infty} a_{n+1}(n+r+1)x^{n+r+1} + \sum_{n=0}^{\infty} a_nx^{n+r+1} - \sum_{n=-1}^{\infty} \frac{a_{n+1}}{2}x^{n+r+1} \\[/itex]
Now I remove terms from each series until I can write the rest of the series starting from n = 0. These extra terms that I removed make up the indicial equation. So for the first sum, I take the first two terms because we are starting at n = -2, and from the second and last sums I remove the first term because those start at n = -1.
So, the sum of the terms I removed is: [itex]a_{2-2}(2+r-2)(-2+r+1)\sin(x)x^{r-1} + a_{2-1}(2+r-1)(1+r-1)\sin(x)x^{r} + a_{1-1}(-1+r+1)x^{-1+r+1} - \frac{a_{-1+1}}{2}x^{-1+r+1} \\[/itex]
Simplifying, and removing the factor of [itex]x^{r} \\[/itex]
[itex]r(r-1)a_0\sin(x)x^{-1} + (r+1)(r)a_1\sin(x) + ra_0 - \frac{a_0}{2} \\[/itex]
So I'm stuck with terms with [itex]a_1[/itex] , [itex]\sin(x)[/itex], and exponentials of x. Is this a legitimate indicial equation? If not, where did I go wrong?
You are going to have to expand [itex]\sin x[/itex] as a taylor series and multiply it by the infinite series for [itex]y''[/itex]. For the origin you get [tex] \sum_{m=0}^\infty \sum_{k=0}^\infty \frac{(-1)^m a_k(k+r)(k+r-1)}{(2m+1)!} x^{2m + k + r - 1} + \sum_{n=0}^\infty a_n(n+r)x^{n+r}<br /> + (x - \tfrac12)\sum_{n=0}^\infty a_nx^{n+r} = 0.[/tex] Now the lowest power of [itex]x[/itex] you can get on the left hand side is [itex]x^{r-1}[/itex], by taking [itex]m= 0[/itex] and [itex]k = 0[/itex] in the product, to get the indicial equation [tex]a_0r(r-1) = 0.[/tex] For the other singular points I would set [itex]x = l\pi + z[/itex] for integer [itex]l[/itex] and [itex]y = \sum_{n=0}^\infty a_n(x - l\pi)^{n+r} = \sum_{n=0}^\infty a_nz^{n+r}[/itex] and use [itex]\sin x = \sin(z + l\pi) = (-1)^l \sin z[/itex] so that the ODE becomes [tex] (-1)^l \sin(z)y'' + (l\pi + z)y' + (z + l\pi - \tfrac12)y = 0.[/tex] From this you see that the [itex]x^{r-1}[/itex] coefficient acquires a contribution from the [itex]l\pi y'[/itex] term.
Thanks for the reply, although I'm not sure I understand your procedure. Firstly, for the Frobenius method, aren't you supposed to normalize the y'' term and multiply everything by [itex]x^2[/itex]? I guess that's not really that important, but can you explain how you found the indicial equation or how you can find the recurrence relation when you have that double sum? Also, why isn't x = 0 the only regular singular point? It looks to me like any multiple of [itex]\pi[/itex] makes [itex]\frac{xp(x)}{a(x)}, \frac{x^2q(x)}{a(x)}[/itex] undefined.
There is no such requirement, and here that actually makes your life vastly more difficult.
If [itex]x_0[/itex] is a regular singular point then the idea of the Frobenius method is that to look for solutions of the form [itex]\sum_{n=0}^\infty a_n(x -x_0)^{n+r}[/itex], where [itex]r[/itex] is fixed by requiring that [itex]a_0 \neq 0[/itex].
Whatever manipulations you perform on the left hand side of the ODE are aimed at turning it into a power series in [itex](x - x_0)[/itex] so that you can compare cofficients of powers of [itex](x - x_0)[/itex] in order to find [itex]r[/itex] and the [itex]a_k[/itex]. Thus any functions of [itex]x[/itex] which are not of that form need to be expanded as Taylor series about [itex]x_0[/itex], and you will therefore need to multiply power series (unless you can make a simplifying substitution first).
In the case of [tex](\sin x)y'' + xy' + (x - \tfrac12)y = 0[/tex] you are going to be multiplying power series: either once as it stands, or twice if you rearrange it as [tex] x^2y'' + \frac{x^3}{\sin x} y' + \frac{x^2(x- \frac12)}{\sin x} y = 0.[/tex] Which would you rather? (Also, can you just write down the power series for [itex]x^3/\sin x[/itex] and [itex]x^2(x - \frac12)/\sin x[/itex] from standard references, as you can with the series for [itex]\sin x[/itex] itself, or are you going to have to calculate them yourself?)
The indicial equation is found by obtaining the coefficient of the lowest power of [itex](x - x_0)[/itex] which occurs after you have turned the ODE into a power series.
We can recover the coefficients indcutively, starting from the arbitrary non-zero [itex]a_0[/itex]. To get terms of order [itex]x^{n+r}[/itex] from the double sum we need to take all pairs of positive integers [itex](m,k)[/itex] such that [itex]2m + k = n + 1[/itex]. As [itex]n[/itex] increases there will be more and more of these, but one of them will be a multiple of [itex]a_{n+1}[/itex] and the others will be multiples of coefficients that we've already recovered. We can write this as a recurrence of the form [itex]a_{n+1} = F(a_0, \dots, a_n, n)[/itex] (note the express dependence on [itex]n[/itex]) but this is maybe more trouble than it's worth.
At the origin, for example, comparing coefficients of order [itex]x^{r-1}[/itex], we have to take [itex]m = k = 0[/itex] in the double sum and the other sums don't give us anything, so [tex] a_0r(r-1) = 0.[/tex] This is the indicial equation. (The roots differ by an integer, so we expect only one linearly independent solution from this; the other will involve a logarithm.)
At order [itex]x^r[/itex] we have to take the [itex](m,k) = (0,1)[/itex] term from the double sum, and we pick up contributions from the [itex]xy'[/itex] and [itex]-\frac12y[/itex] terms ([itex]n = 0[/itex] in both cases) to find [tex] a_1 r(r+1) + a_0r - \tfrac12a_0 = 0.[/tex] Now if [itex]r = 0[/itex] then we get [itex]-\frac12 a_0 = 0[/itex] which is a contradiction, so we must take [itex]r = 1[/itex] and [tex] 2a_1 = -\tfrac12 a_0.[/tex]
At order [itex]x^{r+1}[/itex] we must take both the [itex](m,k) = (1,0)[/itex] and [itex](m,k) = (0,2)[/itex] terms from the double sum and contributions from the other three sums to get [tex] \frac{(-1)a_0r(r-1)}{3!} + a_2(1+r)(2+r) + a_1(1+r) + a_0 - \frac12 a_1 = 0[/tex] and actually the first term vanishes, as in this case all terms with [itex]k = 0[/itex] will.
So far we have [tex]y(x) = a_0\left(x - \frac14 x^2 - \frac{13}{48}x^3 + \dots\right).[/tex] We can, if desired, continue further.
[itex]y'' + p(x)y' + q(x)y = 0[/itex] has a regular singular point at [itex]x_0[/itex] if and only if [itex]p(x)[/itex] has a pole of at most order 1 at [itex]x_0[/itex] and [itex]q(x)[/itex] has a pole of at most order 2 at [itex]x_0[/itex]. Here, [itex]p(x) = x/\sin x[/itex] has a removable discontinuity at [itex]x = 0[/itex] and a pole of order 1 at [itex]x = n\pi[/itex] for [itex]n \neq 0[/itex], while [itex]q(x) = x/\sin x - 1/(2 \sin x)[/itex] has poles of order 1 at all integer multiples of [itex]\pi[/itex]. Thus all integer multiples of [itex]\pi[/itex] are regular singular points.
Thank you very much, this has been very helpful. However, how am I supposed to find the form of the linearly independent solutions near every regular singular point if there are infinitely many of them? I guess there must be a pattern. Trying that now.
