What is the difference between rated speed and output speed in servo motors?
  • Thread starter Thread starter baris45
    Servo Speed
The discussion clarifies the distinction between "rated speed" and "output speed" in servo motors. Rated speed, defined as the maximum speed at rated torque, is typically lower than the maximum output speed, which is achieved under unloaded conditions. In the context of gearboxes, rated speed is influenced by factors such as lubrication and gear types, and while gearboxes may operate at higher speeds, this can lead to increased noise and reduced lifespan. Understanding these differences is crucial for selecting the appropriate servo motor and gearbox combination.
  • Understanding of servo motor specifications, including rated speed and output speed.
  • Knowledge of gearbox mechanics and their impact on motor performance.
  • Familiarity with torque and RPM calculations in motor applications.
  • Basic principles of power in relation to torque and rotational speed.
  • Research the specifications of different servo motors, focusing on rated speed versus output speed.
  • Explore gearbox types and their influence on servo motor performance, particularly in high-speed applications.
  • Study torque and RPM relationships to optimize motor selection for specific applications.
  • Investigate best practices for communicating with suppliers regarding motor and gearbox specifications.
Engineers, technicians, and designers involved in motion control systems, particularly those working with servo motors and gearboxes in industrial applications.
baris45
Hi Everyone,
What is the difference between "Rated speed nC(1/min)" and "output speed" in servo motors.
At the same time While "rated motor speed" is 1405(1/min) in gearbox catalogue, Rated speed is 3000 (1/min) in servo motor catalogue for the same gearbox.
If someone has a knowledge about this kind of servo motor and gearbox, can you inform to me.
Thanks in advance
your question is not all that clear.
generally, rated speed is the max speed at the rated torque, whereas (max) output speed is unloaded. so rated speed is lower than max speed.
Gearboxes have their own speed ratings (depending on the lubrication, gear types, etc, etc). Often times a gearbox will function at a higher speed, but they might be noisier or it could affect lifetime. You should reach out to the supplier or manufacturer directly to clarify conflicting information.
Maybe it is referenced to rated power.
Power is torque multiplied by RPM.
There is no power at zero RPM, or at zero torque.
To get the rated power it operates at the rated RPM and rated torque.
Either the torque or the RPM could be greater than the rated value, but not both at the same time.
@onatirec and @Baluncore Thank you so much for your attention. Your answers brightened to my opinions.
10K
  • · Replies 19 ·
