Complex Plane Points with Re(z)≤0 and |z|=3
  • Thread starter Thread starter Physicsissuef
    Points Set
The discussion focuses on identifying the set of complex plane points that satisfy the conditions Re(z) ≤ 0 and |z| = 3. The solution confirms that the points satisfying Re(z) ≤ 0 correspond to the left half of the complex plane, while |z| = 3 describes a circle of radius 3 centered at the origin. Participants clarify that the intersection of these conditions results in the left semicircle of the circle with radius 3. Additionally, the conversation addresses related conditions involving Re(z) ≥ 0, Im(z) ≥ 0, and |z| ≤ 2, leading to further exploration of geometric representations in the complex plane.
  • Understanding of complex numbers and their representation as points in the complex plane.
  • Familiarity with polar coordinates and the relationship between complex numbers and circular equations.
  • Knowledge of inequalities and their geometric interpretations in two dimensions.
  • Basic skills in graphing circles and regions defined by inequalities.
  • Study the geometric interpretation of complex numbers, focusing on the unit circle and its properties.
  • Learn how to graph inequalities in the complex plane, including circles and semicircles.
  • Explore the use of polar coordinates in complex analysis, particularly the conversion between rectangular and polar forms.
  • Investigate the implications of combining multiple inequalities in the context of the complex plane.
Students studying complex analysis, mathematics educators, and anyone interested in visualizing complex numbers and their properties in the complex plane.
  • #31
No it doesnt.
  • #32
Why it doesn't?
  • #33
You said these were the conditions :
1. Re(z) \geq 0
2. Im(z) \geq 0
3. |z| \leq 2
Part of your picture is to the left of the vertical axis, so it doesn't satisfy (1). Part of your picture is below the horizontal axis, so it doesn't satisfy (2). And part of it is further away from the origin than 2, so it doesn't satisfy (3).
  • #34
Physicsissuef, I see you included points where x < 0 as well as y < 0. Does that not violate two of the requirements?
  • #36
Yes, good job!
You might want to indicate the value of the radius in the figure.
  • #37
  • #38
No.
Try getting the equation (or inequality) in terms of x and y first. By now you've seen enough examples that you should be able to do it.
Then draw the figure.
  • #39
<br /> <br /> 1 \leq x^2+y^2 \leq 9<br /> <br />
But the question is how will I draw it?
  • #40
Do you honestly not recognize equations for simple familiar figures in what you have written? Even after doing numerous similar problems?
To be honest and frank with you, I am wondering how it will be possible for you to answer questions like this on an exam in the future.
  • #41
Do you understand that (and why) x^2 + y^2 = r^2 represents a circle with radius r?
Do you understand that x^2 + y^2 &lt; r^2 represents a disk with radius r, not including the boundary?
  • #42
Redbelly98 please be patient with me... I just started to learn about Complex numbers... I can't be expert with 2 hours of learning for god sake...
For how many times, I understand. r^2=x^2+y^2 because of Pita gore theorem in polar coordinate system.
Lets go back to the problem. Is it like http://i25.tinypic.com/24wya1d.jpg"
  • #43
Is it like that, please I need confirmation. Thank you...
  • #44
Yes, that's correct.
  • #45
  • #46
Yes.
  • #47
Ok, thanks. And what about this http://i26.tinypic.com/jj360y.jpg"
a)1 \leq |z| \leq 2
b)
<br /> -2 \leq Re(z) \leq 2<br />
<br /> -2 \leq Im(z) \leq 2<br />
c)|z-(1,1)| \leq \sqrt{2}
  • #48
(a) and (c) are correct, (b) is wrong.
  • #49
0 \leq Im(z) \leq 2
It was typo. Now is it correct?
  • #50
Yes.
  • #51
Ok, thanks. And can you please tell me about this two pictures. http://i31.tinypic.com/18d3py.jpg" I will be very happy if you can confirm me. Thank you once again...
  • #52
Physicsissuef said:
Ok. Thanks. And for |z| \leq 4, is it like http://i31.tinypic.com/511rno.jpg"
Yes, |z|\le 4, in the complex plane, refers to those points, (x,y), whose distance from (0,0) is less than or equal to 4. That consists of the circle with center at (0,0) and radius 4 as well as its interior.
  • #53
Yes, but can you confirm me about the pictures in the above post, they're not same. Thanks.
  • #54
Yes they're correct.
  • #55
They are all correct? What about i) 0 &lt; |z| \leq 3? How will I make the disk without zero?
  • #56
Usually you put a circle (like an 'o') on the point, instead of a dot.
For example, this could be the line y = 2x + 1, x \neq 3:
Code:
|  o
|_________
  • #57
Ok, thank you, and my other tasks are correct? (I mean, with stuff like shadowing and circles like in this case) Is it correct with the angles?
  • #58
Yes. Don't worry about these things (how to draw it) too much, as long as it's clear what you mean. If your teacher understands what you mean he will most probably accept it, even if the way you have drawn it is maybe not 100% 'conventional'... (I don't even know if there is any convention for things like this... But it's pretty obvious how you've drawn it, so I think you're going to be ok.)
  • #59
Ok. Thank you.
