[Set Theory] Proving Linear Order on a Subset of a Partially Ordered Set
The discussion revolves around proving that a countable subset S of a partially ordered set L has an upper bound in L, given that every countable chain in L has an upper bound. Participants clarify that S is not necessarily linearly ordered, which complicates the proof. Some suggest constructing a chain from specific elements of S to find an upper bound, while others emphasize that just because an element c is greater than or equal to a and b, it does not imply c is an upper bound for all of S. The conversation highlights the need for explicit examples to better understand the relationships between elements in S. Ultimately, the challenge lies in demonstrating that S can be bounded despite its lack of linearity.
EstimatedEyes
Let L be a partially ordered set. Every countable chain in L has an upper bound. Let S be a countable subset of L such that for arbitrary a,b in S there exists a c in S such that a (less-than-or-equal) c and b (less-than-or-equal) c. Prove S has an upper bound in L.
Definition of linear, partial orders.
I assume the goal is to prove that S is linearly ordered and thus a chain, having an upper bound in L by the problem text. S is clearly a partial order because it is a subset of L. After listing the properties of a partial order, I have no idea how to continue. Any help would be greatly appreciated! Thanks!
S is not a chain in general. So you won't be able to prove that. But try selecting a few elements in S which DO form a chain. This chain will have an upper bound. And if you selected the elements correctly, then the upper bound of the chain, will be an upper bound of S...
Okay, I assume that a,b, and c are the elements to which you are referring. Obviously a and b are comparable with c but I am having trouble showing that it then follows that a is comparable with b. I know it can't be this easy, but I don't completely understand why c is not already an upper bound because it is defined to be greater than or equal to all elements of S. Since S is a subset of L, c must also be an element of L, giving S an upper bound in L. What is wrong with this line of thinking?
No, a, b and c aren't the elements which I had in mind. The chain is somewhat harder to construct... In fact, nothing guarantees you that a and b are comparable. In fact, it isn't even true!
I don't see why it is greater or equal to all elements of S? I only see why it is greater or equal than a and b. But it certeinaly isn't an upper bound of S!
It may help you to think of some explicit examples!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
