MHB Seth's question via email about a Laplace Transform
The Laplace Transform of the function \( 36\left[ \frac{\cosh{\left( 4\,t \right) } - 1}{t} \right] \) is derived using the property for transforms of the form \( \frac{f(t)}{t} \). The function \( f(t) \) is identified as \( \cosh{\left( 4\,t \right)} - 1 \), leading to the transform \( F(s) = \frac{s}{s^2 - 16} - \frac{1}{s} \). The integral for the Laplace Transform is evaluated, resulting in the expression \( -\frac{1}{2} \ln{\left| 1 - \frac{16}{s^2} \right|} \). The final result must include the factor of 36, confirming the correct application of the transform.
Prove It
MHB
Find the Laplace Transform of $\displaystyle 36\left[ \frac{\cosh{\left( 4\,t \right) } - 1}{t} \right] $.
Since this is of the form $\displaystyle \frac{f\left( t \right)}{t} $ we should use $\displaystyle \mathcal{L}\,\left\{ \frac{f\left( t \right) }{t} \right\} = \int_s^{\infty}{F\left( u \right) \,\mathrm{d}u } $.
Here $\displaystyle f\left( t \right) = \cosh{\left( 4\,t \right) } - 1 $ and so
$\displaystyle F\left( s \right) = \frac{s}{s^2 - 16} - \frac{1}{s} $
Therefore
$\displaystyle \begin{align*} \mathcal{L}\,\left\{ \frac{\cosh{\left( 4\,t \right) } - 1}{t} \right\} &= \int_s^{\infty}{ \left( \frac{u}{u^2 - 16} - \frac{1}{u} \right) \,\mathrm{d}u } \\
&= \lim_{b \to \infty}\int_s^b{ \left( \frac{u}{u^2 - 16} - \frac{1}{u} \right) \,\mathrm{d}u } \\
&= \lim_{b \to \infty} \left[ \frac{1}{2}\,\ln{\left| u^2 - 16 \right| } - \ln{\left| u \right| } \right] _s^b \\
&= \frac{1}{2} \lim_{b \to \infty} \left[ \ln{ \left| u^2 - 16 \right| } - 2\,\ln{ \left| u \right| } \right] _s^b \\
&= \frac{1}{2} \lim_{b \to \infty} \left[ \ln{ \left| u^2 - 16 \right| } - \ln{ \left| u^2 \right| } \right] _s^b \\
&= \frac{1}{2} \lim_{b \to \infty} \left[ \ln{ \left| \frac{u^2 - 16}{u^2} \right| } \right] _s^b \\
&= \frac{1}{2} \lim_{b \to \infty} \left[ \ln{ \left| 1 - \frac{16}{u^2} \right| } \right] _s^b \\
&= \frac{1}{2} \left\{ \lim_{b \to \infty} \left[ \ln{ \left| 1 - \frac{16}{b^2} \right| } \right] - \ln{ \left| 1 - \frac{16}{s^2} \right| }\right\} \\ &= \frac{1}{2} \left( \ln{ \left| 1 - 0 \right| } - \ln{ \left| 1 - \frac{16}{s^2} \right| } \right) \\
&= \frac{1}{2} \left( 0 - \ln{ \left| 1 - \frac{16}{s^2} \right| } \right) \\ &= -\frac{1}{2} \, \ln{ \left| 1 - \frac{16}{s^2} \right| } \end{align*} $
Mathematics news on Phys.org
That seems correct to me, I check the tables, you forgot the factor of 36 out front tho.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
