Setting up a particular equation with (cos(x))^2
  • Thread starter Thread starter batmankiller
batmankiller
Find a particular solution yp of the differential equation
2y''+9y'+2y=(cos(x))^2
I'm not really sure where to start? I solve for the homogeneous solution and get C1e^ -4.26556+C2e^-.2344355629=0. I'm just not sure where to go from there. Should I do
y(x)=(Acos(x)+Bsin(x))^2 since it's just cos (x)*cos(x) or is not that right approach?
cos^{2}(x) can be broken up using the half angle formula. You'd get a polynomial (degree one) and a trig function that is expandable under Euler's Formula. Add the particular solutions together to get the final particular solution.
so (cos(x)^2) is ((1+cos (2x))/2.
Which is 1/2 + cos(2x)/2. Am I missing something to get it into a degree one term and a trig function?
For that I get A+ B*cos(2x)+C*sin(2x)?
Sorry, not degree one. I meant it has a constant added to a trig function. But you can solve the equation and get particular solutions by guessing that y = \frac{1}{4} (for one solution) and that y = Re(Ae^{2i\theta}) where A is some constant. Or you can use your method and simply guess A sin(2\theta)+Bcos(2\theta). Add that guess to your other particular solution (y = \frac{1}{4}), then add your particular solutions to your homogeneous solution. This will result in the general solution of the differential equation.
Ah ok, I don't even need the general solution, just the particular solution, so should I just consider the two particular solutions of Asin(2x)+Bcos(2x) and y=1/4 (Solving the constants A and B?)
Yup. Add the two particular's together and you're done!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
