Setting Up an Advanced Mathematics Equation
84 replies · 13K views · last reply
C=90-A
S=180-A
Like that?
That would make my three equations the following:
2s=4c+104 degrees=0
S=180-A
C=90-A
Haha, I tried to click thanks again, and it said I gave out to much Reputation in the last 24 hours. XD
So now I need to work the equations together. Am I adding like terms, or substituting the appropriate equations where I left s and c?
Do whatever works best for you. Your objective is to obtain A and get rid of c and s.
Okay, after plugging in my new equations, I get 2(180-A)=(90-A)+104 degrees=A
If I apply the distributive property in the first part, I get (360-A)=(90-A)+104=A
Can I add 104 to 90, or does that violate an algebraic rule I am forgetting?
The right hand side had 4c originally.
Why do you have two equality signs there? Where does the second one come from?
I was attempting to state that those two equations are equal to both each other and A. Is the =A not supposed to be there?
The original equation was 2s = 4c + 104. You substituted s = 180 - A and c = 90 - A into it. How would that bring about = A to it?
No idea. It snuck it's way in there. So: 2(189-A)=4(90-A)+104 degrees.
I hope 189 was a typo.
Your goal to is to transform the equation to A = ..., where the right hand side does not have A. Use whatever algebraic rules that help you achieve that. It is not too hard.
Major typo. It was meant to be 180. The nine is, of course, right next to the zero, and I was typing too quickly.
Applying distributive property: (360-A)=(360-A)+104.
Combining like terms: (720-2A)+104
Why doesn't that seem right?
Not only that, you did not apply the distr. property to A's.
Right! Take five-billion: (360-2A)=(360-4A)
That should look better.
I forgot the 104. Maybe this will work. (360-2A)=(360-4A)+104
Finally. It astonishes me that I had less trouble with Honors Physics the other day than with basic algebra.
(360-2A)=(464-2A)
Doesn't seem right. Should I subtract the 104 instead of adding?
But that would yield (360-2A)=(256-4A), which also seems wrong.
