Setting up differential equations for oil leakage and fire spread
13 replies · 3K views
Daniiel
Hey I've been studying over my extension math revision and i just can't get my head around these two questions. I'm sure I've been setting up the differential equations wrong but I am not sure what's right. The test is tomorow and tuesday so I am kind of freaking out. here's the two questions, thanks in advance.
1. Oil is leaking out of a barrel loaded in a cargo ship. The rate at which the oil level is dropping seems proportional to the square root of the level of oil in the barrel at that time.
Write a differential equation for y(t), the level of oil (in cms) and time (hours).
Find a general solution for the equation.
If the barrel was filled up to 144cm when it started leaking and the level dropped to 80cm in four hours, how long will it take for the barrel to empty?
2. An investigation is under way in the department of forests, land and conservation to improve our understanding of the rate at which bush fires spread. A bush fire has broken out and a spotter plane has already taken some photographs. The first photograph shows a fire area of half a hectare. Comparison with a photograph taken six hours later shows that the fire seems to be spreading uniformly in all directions and has burned an additional 1700 square metres.
Use differential equations and find two possible models for the spread of the fire.
i have been for q1, dr/dt = y^(1/2). fliping to dt/dr then intergrating
just some assitance with setting up the beginning equation will be enough to get me going its just the start of these i get confused about
thankyou =D
What's r? Isn't the first equation just dy/dt=k*y^(1/2)? Separate the variables and integrate both sides. I.e y^(-1/2)*dy=k*dt where k is the constant of proportionality. Is that enough to get you started? Stop freaking out.
thankyou =D
Well, in words the rate at which the oil drops out, is a measure of how quickly the level of oil in the tank decreases...in math that would be Rate=dy/dt. Now this rate is proportional to the square root of the level of oil in the tank,
i.e. [tex]\frac{dy}{dt} \propto y^{1/2}[/tex]
or [tex]\frac{dy}{dt} = Cy^{1/2}[/tex] where [tex]C[/tex] is some unknown constant of proportionality.
Now can you use a similar line of reasoning in the second question to set up a DE for the area burned, [tex]A(t)[/tex]?
dy/dt=ky^1/2
dy= ky^1/2 dt
y^(-1/2) dy = kdt integrate
y^1/2 / [1/2] =kt +c
2 y^1/2 = kt +c
when t=0 y=144 substitute
2[sqrt[144]] =k0+c
c=24
2y^1/2 = kt +24
when t=4 y=80 substitute
2 sqrt80 =k[4] +24
2[4sqrt5]-24 =4k
k= 2sqrt5 -6
2y^1/2 =[2sqrt5 -6] t +24 answer
y^1/2 =sqrt5 -3] t +12
when y=0 what is t ?
set y=0
0=[sqrt5 -3]t +12
t= 12 / [3-sqrt5]
thats what i had before, but the original ky^1/2 should be -?
and for the second question i did
A=pi r^2
where r is the radius of th burnt area
the rate of expansion is dr/dt. Buy dr/dt is a constant k
dA/dt = 2 pi r k
dA = 2pi r k dt
A=pi R^2 k t +c
at t=0 A(0) = 1/2 hectare
A(0)=pi r^2 k[0]+c
c=A(0)
A= pi r^2 k t +A(0)
at t=6 A(6) = 1700 metres sq. + A(0) solve for r(6) and substitute
A(6)= pi [r(6)^2] 6 k +A(0) solve for k
k is rate of the fire is advancing
are they right?
Daniiel said:
dy/dt=ky^1/2
dy= ky^1/2 dt
2 y^1/2 = kt +c
2[sqrt[144]] =k0+c
c=24
2y^1/2 = kt +24
2 sqrt80 =k[4] +24
2[4sqrt5]-24 =4k
k= 2sqrt5 -6
set y=0
0=[sqrt5 -3]t +12
t= 12 / [3-sqrt5]
A=pi r^2
dA/dt = 2 pi r k
dA = 2pi r k dt
A=pi R^2 k t +c
A(0)=pi r^2 k[0]+c
c=A(0)
A= pi r^2 k t +A(0)
are they right?
Your solution to question (1) is correct. There is no need to worry whether to use +k or -k in the ODE, because if you use +k you get a k that is always less than zero and so the negative sign is built in.
Question 2 is more complicated. You don't know that dr/dt is a constant, it could be almost any function of t. The question asks you to find two different solutions, so the easiest ones are probably: (a) dr/dt=k and (b) dr/dt=Ct+D, but you could choose almost any function as long as you don't have to use too many constants (you only have two initial conditions. so you can only solve for two constants).
Anyways, good luck on your test and remember to clearly define your variables! (unless they are already defined in the question)
thanks for your reply
but it says the fire is spreading uniformly
wouldnt that make dr/dt a constant
this is how i got one of the formulas
im still puzzled on the second haha
http://img140.imageshack.us/my.php?image=fireee0.jpg
I take "spreading uniformly" to mean that the fire isn't growing faster to the left of the center of the burned area than it is to the right of center...that just means that dr/dt won't be some complicated function of r,it can still be a function of t though: it may have burned faster in the last 3 hours than it did in the first 3, but that doesn't mean it isn't spreading uniformly out from the center.
ah damn
i got to redo it then
my classmate got for one of the equations
5000e^(0.488t)
im not sure how he did it though
Daniiel said:
ah damn
5000e^(0.488t)
he probably set dr/dt =Ae^(Bt) and then solved for A and B... this would be another valid solution, but I think there are many others aswell.
Daniiel said:
ohh thanks for your help
so my equation is junk?
No, your equation is fine; it's just one of many possible solutions, and the question asked for two different solutions so you only answered half the question.
ohh thanks for all your help
i worked out the dr/dt =Ae^(Bt) one, that was so much easyer then all that stuff i did
i think i might redo mine because the r(t) part doesn't seem correct, it makes the equation only really work when you know the radius or the area
just to bug you one more time haha, would you know of any other ways like dr/dt =Ae^(Bt) i could get another equation?
I could think of MANY: dr/dt=At^423876.227 or dr/dt =Bsinh(t^3/(4t-1)) for example, but the easiest two to solve are probably dr/dt=k and dr/dt=Ae^Bt.
The question is very ambiguous, and I don't think you would see one worded like that on an exam.
