Setup 100baseTX LAN: Tips and Considerations
  • Thread starter Thread starter Mudvaynelethaldosage
    Network
The discussion focuses on transitioning a 10baseT LAN setup to a 100baseTX configuration between two PCs using an Ethernet crossover cable. The current connection operates at 10Mbps in half duplex, while both Network Interface Cards (NICs) support 100baseTX. Users are advised to manually configure the NIC properties to attempt a higher speed connection, although issues may arise if the cable or settings are not compatible. Full duplex operation is emphasized as a means to achieve better performance without collisions, but it does not yield a combined 200Mbps throughput.
  • Understanding of Ethernet standards, specifically 10baseT and 100baseTX
  • Familiarity with Network Interface Card (NIC) configurations
  • Knowledge of Ethernet crossover cables and their applications
  • Basic concepts of duplex communication: half duplex vs. full duplex
  • Research how to configure NIC properties for 100baseTX in Windows or Linux
  • Learn about Ethernet crossover cable specifications and their importance
  • Explore the differences in performance between half duplex and full duplex Ethernet
  • Investigate potential issues with cable quality and its impact on network speed
This discussion is beneficial for network engineers, IT professionals, and hobbyists looking to optimize local area network (LAN) setups and enhance data transfer speeds between connected devices.
I just set up a 10baseT LAN between 2 pcs with an ethernet crossover cable. It operates at 10Mbps, half duplex. I know the ethernet card in this pc supports 100baseTX, and I'm pretty sure the NIC in the other pc does as well.
I'd like to set them to 100baseTX and full duplex to try to get a 200Mbps connection. Is there anything I should know about doing this? I don't share the internet connection, it's dial up and extremely slow.
I should also note that the 10baseT connection was automatically set because both NICs were set to autodetect by default.
Thank you.
Computer science news on Phys.org
Usually the cards will negotiate the best speed when set to auto.
Is it a cable you bought or made yourself?
It could be a bad cable i suppose, but not likely if you bought it.
You could try forcing the higher speeds by going into the properties of each card. Might work, might not.
Thank you.
always buy cat5 unless you are doing some crazy specialty networking (like 10Gb ethernet).
A cat-5 cable would require a hub or router though.
I think I was a little misunderstood. I have a 10Mbps network running from NIC to NIC that is actively running on this pc as I type. I was just wondering if there would be any unforseen problems with switching it over to 100Mbps.
However, I already tried switching to 100Mbps and it didn't work. I'm just going to have to mess with when I have the time and motivation, or try switching to full duplex so I can get a 20Mbps connection.
You don't get 200Mps on full duplex, you get 100 in both directions, which can also get in half duplex, but you will have many collisions. If your Card supports 100 then you can use 100 no problems
As long as its a cross connect you won't need a Hub, and you definitely won't need a router.
Half Duplex is what you call simplex in telecoms, and uses 2 wires, Full duplex uses 4 wires (or 2 pairs), and thus you can send a receive data on a different pair of wires and thus you don't have any collisions..
http://en.wikipedia.org/wiki/Full-duplex
a cat5 crossover cable would not require a hub.
Thank you anttech. That cleared up the main thing I was wondering about. As for the other, I'll figure it out myself.
20K
