Shape of elementary particles in QFT, etc?
41 replies · 6K views
icantevenn
Hello,
I hope this is not a stupid question as I am not a physicist. But I was curious about how contenders for the so-called Theory of Everything view the shape of the elementary particles. I know that the basic idea of string theory is related to the shape of elementary particles as one dimensional, as opposed to zero-dimensions of classical mechanics, to include Quantum Theory. I am curious what is the shape of elementary particles in other theories that seek to unify QT and GR, such as Quantum Field Theory?
Thanks.
Quantum Field Theory (QFT) doesn't unify QT and GR, it applies the framework of QT to classical special relativistic field theories.
In QFT, particles are assumed to be point-like.
Shayan.J said:
Quantum Field Theory (QFT) doesn't unify QT and GR, it applies the framework of QT to classical special relativistic field theories. In QFT, particles are assumed to be point-like.
That's true, but just to flesh it out a bit more.
For GR see:
https://arxiv.org/abs/1209.3511
And what a particle is in QFT is a bit more nuanced - its analious to what's happening in the quantum treatment of the harmonic oscillator:
http://www.damtp.cam.ac.uk/user/tong/qft/qft.pdf
Thanks
Bill
I guess I used the wrong word. What I meant, I realize, is Quantum Gravity and not QFT.
For GR see:
Thanks
Bill
Just read the above paper, interesting. Is it possible the electron fields are subject to interpretations too like the wave function in QM where the electron fields can also be real like Bohmian?
Demystifier said:
If fields are considered as beables (i.e. elements of reality) then an appropriate detector can be constructed that should be able to detect such fields? But the fields are everywhere, it should be able to detect them like the microwave background radiation?
Even in classical field theory you detect not fields as such but field variations.
Can the theoretical bohmian quantum fields also have field variations?
The microwave background radiation was discovered accidentally.
What kinds of setups can theoretically detect these bohmian quantum fields variations?
How do you detect light from the bulb?
The electromagnetic field is real in QED.. but in electron or quark matter fields.. they are not beables in orthodox QFT.. so are you saying the bohmian electron field can be detected by bohmian electron field detector? What kind of detector can differentiate between electromagnetic field and bohmian electron, quark fields?
Just to elaborate the reason classical fields are considered 'real' is because they carry energy and momentum. Things are more 'obscure' in QFT because the fields are quantum operators which are rather mathematical to begin with. The 'realty', if such exists are like to be with the Fock space thee operators act on.
Thanks
Bill
Again its reality is an interpretational issue. Classically its real - but in QFT its much more complicated.
Thanks
Bill
Electromagnetic field is not a beable in orthodox QFT.
anorlunda said:
That is what I was taught. But another recent thread pointed me to "transversely shaped photons" and to Bessel beams as an example of how to shape them.
I don't understand. Point-like photons and shaped photons sounds like a contradiction. What gives?
Photons are pointlike, while the shape is the shape of the wave function. One should distinguish the photon from its wave function.
Thanks
Bill
So since the quantum fields in Bohmian QFT is a beable.. and this is supposed to be really there.. so what kind of instruments can theoretically image Bohmian electron fields for example? For bohmians particles. We can see them with our own eyes.
This thread is kind of drifting.
I think the OP needs to clearly specify what he means by "shape". What measurements would one make to determine "shape". Only then can we discuss what theoretical predictions are with any confidence. For example, for a charged particle, one might ask if the electric field lines are identical to what is produced from a small charged sphere or whether and how they deviate.
You are missing a key point.
BM has been deliberately cooked up to be indistinguishable from standard QM so there is no way to do what you suggest.
There was a bit of interest in doing that a while ago eg:
http://arxiv.org/abs/quant-ph/0206196
However it soon became apparent it was incorrect. When you think about it it must be the case as it reduces to standard QM there is unlikely any way to tell the the difference.
Thanks
Bill
A compass routinely detects the direction of the magnetic field itself not only deviations.
A point particle is a particle responding to an external electromagnetic field like a classical point charge. Point-like means it is almost that - the e/m form factor deviates from it only through corrections by other fields. Thus being pointlike or not is a property of the particle species just like mass, charge, or spin.
The shape of a particle is, in contrast, a property of the state of the particle just like mean position (if it exists), mean momentum etc. Hence it depends on the particular electron, photon etc. you are considering. It is given in the Heisenberg picture by ##\psi^*E(x)\psi## where ##E(x)## is the relativistic energy density operator. The geometric shape is obtained as the set of ##x## where this is significant - similarly to how one speaks of the shape of a cloud or the corona of the sun.
In quantum gravity the only particle is the graviton, and it is pointlike, with properties similar to the photon.
As with the photon, there are no longitudinal modes but only two helicity modes, and therefore no position operator exists and it is impossible to define a consistent probability of being in any given bounded region of time.
In a unified quantum field theory of gravity and standard model one expects the properties of the combined particle content. But in a unifying string theory, the most elementary systems would be no longer particles but extended strings.
When you see a macroscopic object, e.g. a chair, do you see the particles or the field?
Interesting argument, but let me try to a give a counterargument. Suppose that, for convenience, I fix some gauge condition so that I can ignore the fact that electrodynamics is a gauge theory. Then I can say that the fundamental dynamical fields are not ##E## and ##B##, but the potential ##A^{\mu}##. Then the force on the compass is not given by ##A^{\mu}## itself, but by derivatives of ##A^{\mu}##. The derivatives of the field describe how the field changes.
By the way, even without gauge fixing one can argue that ##A^{\mu}## is more fundamental than ##E## and ##B## due to the Aharonov-Bohm effect.
Well, I think there's a lot of confusion in this thread. In my opinion it doesn't make any sense to talk about "shape" of an elementary particle in the context of QT. As this is about relativistic QT the best and even oversuccessful model is the Standard Model of elementary particles based on local relativistic QFT. "Elementary particle" is here defined in a quite abstract way by the single-particle Fock states of a local irreducible unitary representation of (a covering) of the proper orthochronous Poincare group.
As was stressed already in one posting above, nothing makes sense in physics, if you can't define it in terms of how to observe/measure it in the lab. We observe particles with several detectors. For the very general question posed here, it's sufficient to discuss one simple possibility. So take a charged elementary particle (like an electron). It can be detected by a photo plate. If the electron hits the plate it leaves a single spot at some position, which is not determined before but we know, given the usual setup of a particle collider, where one prepares particles with rather well defined momentum (and thus also energy), a probability distribution for the position of the particle, where it hits the photo plate. Any single electron will make a spot at a position that is determined with some uncertainty, roughly given by the grain size of the photo plate. That's it. There's nothing defining a "shape" in any sense. All you can see in a microscope is the shape of the grain of your photo plate. You may use other, more modern ways to detect the particle like a CCD camera or an electromagnetic calorimeter. So here the "shape" of a "pixel" varies arbitrarily, dependent on the specific setup of the detector, but all this doesn't determine anything about the elementary particle under investigation but only about the detectors used to observe it.
So it's pretty clear that an elementary particle, as we define them today, has nothing observable that can be identified as any kind of "shape" in the usual sense of what we understand by this notion in the macroscopic world. An elementary particle is identified by its mass, spin, and various charges describing how it interacts via the fundamental interactions described by the Standard Model (strong and electroweak forces). There's not more we know about them, and that's all we can observe today.
The electromagnetic field describes how the vector potential changes. But the field itself is measured, not the potential.
This holds for elementary particles as anonymous, indistinguishable objects, but not for particular ones. Individual particles (made distinguishable by putting them into context, e.g. the outer electron of an atom in an ion trap, or a single photon in a beam created by a photons-on-demand source, have more properties, namely those determined by their state. So they have a shape, as described in my other post. At least this is the way how people working in the field talk about it.
Sure, but how do you define "shape"? Note that it must be an intrinsic property, defined in the particle's frame (let's concentrate on massive particles which at least have a position in the literal sense). What you described is not the shape of a particle but the shape (or better said pattern) of probability (distributions) of observables. E.g., I'd not say an electron in the ground state of a hydrogen atom is a sphere with extension of one Bohr radius. When I measure, e.g., it's position I'll find a "pointlike" spot on the detector (thereby kicking it out of the bound state).
