Solving Integrals with "Sommerfeld substitution
  • Thread starter Thread starter coomast
    Knowledge
The discussion focuses on the "Sommerfeld substitution," a method for solving specific integrals involving trigonometric functions and a parameter ε. The integrals addressed include \(\int \frac{1}{1+\epsilon \cdot \cos \theta}d\theta\) and \(\int \frac{\sin \theta}{(1+\epsilon \cdot \cos \theta)^2}d\theta\). By using the substitution \(1+\epsilon \cdot \cos \theta = \frac{1-\epsilon^2}{1-\epsilon \cdot \cos \gamma}\), the integrals can be simplified and solved systematically. This substitution is particularly effective for integrals that are otherwise non-trivial.
  • Understanding of integral calculus
  • Familiarity with trigonometric functions
  • Knowledge of substitution methods in integration
  • Basic grasp of the properties of the cosine and sine functions
  • Explore advanced techniques in integral calculus, such as contour integration
  • Study the applications of the Sommerfeld substitution in physics problems
  • Learn about other substitution methods for solving integrals
  • Investigate the historical context and significance of the Sommerfeld substitution in mathematical literature
Mathematicians, physicists, and students of calculus who are looking to enhance their skills in solving complex integrals, particularly those involving trigonometric functions and parameterized equations.
coomast
Some time ago I had to do a calculation concerning a physical problem. In this calculation some integrals were needed to be solved and the method on how to do this was briefly described. I was able to solve the problem completely and found the method so beautiful that I would like to share it with all of you. Consider the following integrals:
\int \frac{1}{1+\epsilon \cdot cos \theta}d\theta
\int \frac{1}{\left(1+\epsilon \cdot cos \theta\right)^2}d\theta
\int \frac{1}{\left(1+\epsilon \cdot cos \theta\right)^3}d\theta
\int \frac{cos \theta}{1+\epsilon \cdot cos \theta}d\theta
\int \frac{cos \theta}{\left(1+\epsilon \cdot cos \theta\right)^2}d\theta
\int \frac{cos \theta}{\left(1+\epsilon \cdot cos \theta\right)^3}d\theta
\int \frac{sin \theta}{1+\epsilon \cdot cos \theta}d\theta
\int \frac{sin \theta}{\left(1+\epsilon \cdot cos \theta\right)^2}d\theta
\int \frac{sin \theta}{\left(1+\epsilon \cdot cos \theta\right)^3}d\theta
Some of these are straightforward, but some are not. In order to solve the non trivial ones in a systematic way, one can use the following substitution:
1+\epsilon \cdot cos \theta = \frac{1-\epsilon^2}{1-\epsilon \cdot cos \gamma}
With:
0\leq \theta \leq 2\pi
0\leq \gamma \leq 2\pi
The following relations can be obtained:
cos \theta = \frac{cos \gamma -\epsilon}{1-\epsilon \cdot cos \gamma}
sin \theta = \frac{\sqrt{1-\epsilon^2} sin \gamma}{1-\epsilon \cdot cos \gamma}
cos \gamma = \frac{\epsilon +cos \theta}{1+\epsilon \cdot cos \theta}
sin \gamma = \frac{\sqrt{1-\epsilon^2} sin \theta}{1+\epsilon \cdot cos \theta}
d \theta = \frac{\sqrt{1-\epsilon^2}}{1-\epsilon \cdot cos \gamma}d \gamma
d \gamma = \frac{\sqrt{1-\epsilon^2}}{1+\epsilon \cdot cos \theta}d \theta
After rewriting some of the integrals into smaller ones, substituting this and rearranging it is possible to solve them in a fairly easy way. As an example, let's take the one before the last, it was:
Using the substitution we get:
\int \frac{sin \gamma}{1-\epsilon^2}d\gamma=\frac{-cos \gamma}{1-\epsilon^2}+C
The solution is now obtained by substituting either
\gamma = arccos \left( \frac{\epsilon +cos \theta}{1+\epsilon \cdot cos \theta} \right)
or
\gamma = arcsin \left( \frac{\sqrt{1-\epsilon^2} sin \theta}{1+\epsilon \cdot cos \theta} \right)
This substitution is called the "Sommerfeld substitution" after the "inventor" and is one of the nicest substitutions I've ever encountered for solving integrals in the real with "classical" functions. I hope this is helpful in solving other types of integrals you might be working on.
best regards,
Coomast
your information was very useful thanks
very nice
and very useful
thanx
  • · Replies 29 ·
  • · Replies 16 ·
