Shear cell testing, want to understand it completely
Shear cell testing is crucial for determining the cohesive strength of materials, particularly in applications like pharmaceuticals. The process involves applying shear force until the sample fractures, with cohesive strength calculated by dividing the shear force at fracture by the shearing cross-section. ASTM guidelines, such as D-1002 and D-3654, provide standards for testing, emphasizing the importance of factors like surface preparation and adhesive type. The discussion highlights the need to differentiate between shear and tensile testing, as the method may vary based on the material and configuration. Understanding these principles is essential for accurately conducting shear cell tests and interpreting results.
Educateme
Hello,
I am working on a project where I will have to do some shear cell testing, I have some basic under standing (very basic). and I have done some research on the internet. I have a shear cell tester. it is very basic, geared motor with a rod to push on sample , which is under a weight. I believe what I am looking for is cohesive strength of a material. Between the rod and sample I will have a load cell which is hooked up to a data acquisition unit. This will let me record the applied force on the side of the sample. I believe this will give me a "shear force" value. My question is how do I determine the cohesive strength?? I am sorry If this question seem vague. I am left with this project on my hands , and I am trying to do my best to figure it out. I never had the opportunity to learn the whole theory behind shear cell testing from my prior boss (left the company), which was the guy who normally did the tests. Thank you all.
Have you looked under any ASTM guidelines for this type of testing? It appears that this type of testing is very well used in the pharmaceutical world.
yes, well I found a spec.( which I have to purchase a copy) I am working on it as wee speak. Thanks
To find the cohesive strength you need to shear the sample till it fractures. The shear force at fracture divided by the shearing cross section is the cohesive strength.
Note: I've only heard the term "cohesive strength" used in tensile testing. Are you certain it is a shear test that you want to perform?
Are you testing adhesive failure of a lap shear joint? As Gokul indicated, strength is defined by the load at break/bond area. The test may be sensitive to strain rate.
ASTM D-1002 (adhesively bonded single lap joint), D-3654 (time to failure, static load), D-903 (180 degree peel), D-1876 (T-peel)
Remember, you will be testing the whole method including surface prep, surface energy, adhesive type, cure chemistry/schedule, temperature, etc...
Be aware that thinner samples can cause a change in geometry during the application of stress and could convert a lap-shear to a cleavage type shear.
Well after a discussion with another engineer , I believe I now understand what will be need to do. The test is similar in nature to a shear cell test, how ever it will not be a S/C test. It will be more of a tension test I believe. I will be using an old shear cell test set, which I had to make repairs to. What I will be doing is measuring the force it takes to shear a sample against a few different pieces of steel. I will be looking to the static and kinetic Cohesive strengths. Thank you all for your help.
What mathematics software should engineering students use? Is it correct that much of the engineering industry relies on MATLAB, making it the tool many graduates will encounter in professional settings? How does SageMath compare? It is a free package that supports both numerical and symbolic computation and can be installed on various platforms. Could it become more widely used because it is freely available? I am an academic who has taught engineering mathematics, and taught the...
