SHO: Find amplitude given k, and x,v,a at unknown time
The problem involves a block attached to a spring undergoing simple harmonic motion, with known values for position, velocity, and acceleration at an unknown time. The goal is to find the period of oscillation, the mass of the block, and the amplitude of oscillation, given the spring constant k.
  • Participants discuss the relationship between velocity, acceleration, and position, with some attempting to derive expressions for angular frequency and amplitude. Questions arise about the setup of the problem and the interpretation of the given values.
Some participants have offered insights into the relationships between the variables involved, while others express confusion about deriving the amplitude from the provided information. There is an ongoing exploration of the mathematical relationships without a clear consensus on the next steps.
Participants clarify that the problem takes place on a horizontal plane, which may influence the interpretation of the motion and the equations used.
jdp1991
A block attached to a spring is experiencing simple harmonic motion. You know the value of postion, velocity, and acceleration at an unknown time. Find the period of oscillation, the mass of the block, and the amplitude of oscillation.
We were given values for k, x, v, a
F=ma=kx
Tspring=2∏√(m/k)
x=Acos(ωt+phi)
This was the final question on an exam I just took and I was baffled about how to find Amplitude. We were given values for position, velocity, and acceleration, but I cannot remember what they were off the top of my head, so an algebraic solution is fine.
I started my finding the mass of the block by setting kx=ma: m=kx/a
I then plugged that value for m into the spring period equation: T=2∏√((kx/a)/k)=2∏√(x/a)
The previous two I'm not confident about, but I was completely lost when asked to find the amplitude.
Thanks
EDIT: The problem takes place on a horizontal plane (a flat frictionless surface)
How are velocity and acceleration related to the position?
Is this on a horizontal or vertical plane?
velocity = dx/dt and acceleration = d2x/dt2?
So v = -ωAsin(ωt+phi)
and a = -ω2Acos(ωt+phi)
Sorry horizontal
So, a/x = -ω2 . Gives you ω.
Then x2 + (v/ω)2 = A2
ok that makes sense
maybe I'm missing something obvious, but how did you get this?
jdp1991 said:
EDIT: The problem takes place on a vertical plane
jdp1991 said:
Sorry horizontal
Still a little lost :3
OOPS! Haha sorry it should be horizontal.
jdp1991 said:
ok that makes sense
Did you try it.
sin2(θ) + cos2(θ) = 1
