Short exact sequences and group homomorphisms
The discussion centers on the properties of short exact sequences in abstract algebra, specifically the sequence $1 \longrightarrow N \longrightarrow^{\phi} G \longrightarrow^{\psi} H \longrightarrow 1$. The participant has established that $\phi$ is injective, $\psi$ is surjective, and $N$ is normal in $G$, leading to the conclusion that $H \cong G/N$. To demonstrate that $G \cong N \times H$, it is necessary to show that $G/N$ is normal in $G$. The participant suggests using the natural projection mapping and highlights the importance of the mapping $j: H \longrightarrow G$ in this context.
  • Understanding of short exact sequences in group theory
  • Familiarity with group homomorphisms and isomorphisms
  • Knowledge of normal subgroups and their properties
  • Concept of internal and external direct products of groups
  • Study the properties of normal subgroups in relation to short exact sequences
  • Explore the concept of internal direct products in group theory
  • Learn about the natural projection mapping in the context of group homomorphisms
  • Investigate the implications of abelian versus non-abelian groups in direct product structures
Mathematicians, particularly those specializing in abstract algebra, group theorists, and students seeking to deepen their understanding of group homomorphisms and exact sequences.
myownsavior
Abstract algebra question. Given the short exact sequence
$ 1 \longrightarrow N \longrightarrow^{\phi} G \longrightarrow^{\psi} H \longrightarrow 1 $
I need to show that given a mapping $ j: H \longrightarrow G, and $ \psi \circ j = Id_h $ (the identity on H), then $ G \cong N \times H. (The internal direct product).
So far I have proved the following: $ \phi $ is injective, $ \psi $ is surjective, N is normal in G, and $ H \cong G/N $.
Now since I know $ H \cong G/N $, for this isomorphism $ G \cong N \times H to be true, wouldn't I need to show that G/N is normal in G?
I think the natural projection mapping is the right path (mapping g in G to its coset in G/N), but I can't get it to be an internal direct product..
You have to use j at some point. Note that the image of j is isomorphic to H.
Edit: Are N, G, H supposed to be abelian? Otherwise you only get a "twisted direct product".
I think I got it, K: NxH -> G, taking (n,h) -> n*j(h). I forgot that internal direct products are isomorphic to the external direct products in the finite case.
