Show aβ is a Basis for ℝ over Q
  • Thread starter Thread starter SMA_01
    Basis
The discussion revolves around the concept of showing that the set aβ, where β is a basis for ℝ over Q and a is a non-zero real number, is also a basis for ℝ over Q. Participants are exploring the requirements for linear independence and spanning in the context of an uncountably infinite dimensional vector space.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to demonstrate linear independence and spanning for the set aβ. There are attempts to clarify the definitions and implications of linear independence, particularly in relation to finite subsets of aβ. Questions arise about the nature of a basis for ℝ over Q and how it can be represented.
The discussion is ongoing, with participants seeking clarification on the definitions and requirements for linear independence. Some guidance has been offered regarding the need to consider finite subsets and the implications of linear combinations. There is an acknowledgment of the complexity of the problem due to the uncountable nature of the basis.
Participants express confusion regarding the implications of working with an uncountably infinite dimensional space and the nature of finite subsets in this context. There is a focus on understanding the definitions of linear independence and the requirements for a set to be considered a basis.
SMA_01
Let β be a basis for ℝ over Q (the set of all rational numbers) and let a[itex]\in[/itex]ℝ, a≠1.
Show that aβ={ay|y[itex]\in[/itex]β} is a basis for ℝ over Q for all a≠0.
So I need to show (1) Linear independence, and (2) spanning. I am a little confused, especially because the dimension for the vector space is uncountably infinite.
Here is what I have for linear independence:
I took a finite subset of aβ, {az|z[itex]\in[/itex]S[itex]\subset[/itex]β, |S|<|ℝ|} (not sure if I wrote that correctly), so if
[itex]\sum_{z\in S}[/itex]az=0
then z must be zero since a≠0 (initial assumption). Therefore, it follows that aβ is linearly independent.
Is this correct?
I don't know how to approach spanning.
Thanks in advance.
This seems like armwaving to me.
Is this correct?
Do you have a sense of what this problem is about? In particular, what a basis over Q that spans R might look like? For example, can you list a few of the basis elements of such a basis?
Given that β is some basis, you need to show that aβ is also a basis, where a ≠ 0.
To show that any set is a basis for some space, you need to do two things:
1. Show that the set of basis elements is linearly independent.
2. Show that the set of basis elements spans the space.
The latter requirement means that if x ##\in## R, then x can be written as a linear combination of the basis elements.
Honestly, I can't fully grasp it intuitively. I know how a basis is for ℝ with n-dimension, but not ℝ.
I just can't see how something can span ℝ, is the standard basis applicable here?
If I can't show linear independence/spanning the usual way, how should I do this?
Thanks.
You do show independence the usual way. You need to show that for any finite subset ##\{v_1,v_2,\dots,v_n\} \subset a\beta## that
$$q_1 v_1 + q_2 v_2 + \cdots + q_n v_n = 0$$ implies ##q_1=q_2=\cdots=q_n=0##, where ##q_i \in \mathbb{Q}##. What you wrote above doesn't show this. For one thing, there's no mention of the ##q_i##'s.
But a basis for ℝ over Q is uncountable, so how can I take a finite, countable subset?
Because that's the definition of linear independence. To show it's linearly independent you need to show every finite subset is linearly independent.
Okay, correct me if I'm wrong, but if I take a finite subset, I thought it won't be countable? Like I can't order the terms...
Finite implies countable.
So if I take a finite subset of ℝ, then I can order the terms? Sorry, I just want to clarify.
What's the precise definition of finite? If you know this basic definition, you should be able to answer your own question.
