Show [itex]\phi[/itex][itex]\circ[/itex]f is Riemann integrable
  • Thread starter Thread starter IntroAnalysis
    Riemann
The problem involves demonstrating that the composition of a Riemann integrable function \( f \) and a continuously differentiable, monotone increasing function \( \phi \) is also Riemann integrable. The original poster outlines the properties of \( f \) and \( \phi \) and references the Riemann lemma as a basis for their argument.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the definitions of upper and lower Riemann sums and their relevance to the problem. There is an exploration of how to relate the sums for \( \phi(f(c_i)) \) and \( f(c_i) \) based on the properties of \( \phi \). Questions arise about the maximum and minimum values of \( \phi \) at specific points and how these relate to the overall integrability.
The discussion is ongoing, with participants providing insights into the definitions and properties of Riemann sums. Some suggest that the monotonicity of \( \phi \) can simplify the argument, while others seek clarification on the necessity of certain inequalities and relationships between the sums.
There is an emphasis on using the Riemann lemma and the properties of bounded functions. Participants are considering the implications of the Extreme Value Theorem and the differentiability of \( \phi \) in their reasoning.
IntroAnalysis
Let f:[a, b][itex]\rightarrow[/itex][m, M] be a Riemann integrable function and let
[itex]\phi[/itex]:[m, M][itex]\rightarrow[/itex]R be a continuously differentable function
such that [itex]\phi[/itex]'(t) [itex]\geq[/itex]0 [itex]\forall[/itex]t (i.e. [itex]\phi[/itex]
is monotone increasing). Using only Reimann lemma, show that the composition [itex]\phi[/itex][itex]\circ[/itex]f is Riemann integrable.
Riemann lemma - f: [a, b] [itex]\rightarrow[/itex] is Riemann integrable iff for any [itex]\epsilon[/itex]>0 [itex]\exists[/itex]a partition P such that U(P, f) - L(P, f) < [itex]\epsilon[/itex].
Function f is Riemann integrable hence it is bounded by [m, M]. Thus [itex]\forall[/itex]
x[itex]\in[/itex][a, b],lf(x)l [itex]\leq[/itex] max{m, M}.
Also, since the domain of [itex]\phi[/itex] is compact and the function is monotone and increasing, by the Extreme Value Theorem, it achieves a maximum and a minimum on [m, M], hence [itex]\phi[/itex] is also bounded. Thus, [itex]\phi[/itex]((f(a)) and [itex]\phi[/itex](f(b)) is bounded by some constant, K.
Also know since f is Riemann integrable that there exists a partition P such that
U(P, f) - L (P, f)< [itex]\epsilon[/itex]
We must show U(P,[itex]\phi[/itex](f(x))) - L(P, [itex]\phi[/itex](f(x)))<[itex]\epsilon[/itex].
I think I have most of the major pieces, can someone suggest how to put it together?
Thank you.
Why don't you start by writing out the definition of
[tex]U(P,f)-L(P,f)[/tex]
The upper Riemann sum = (i=1[itex]\rightarrow[/itex]n) [itex]\sum[/itex]MiΔxi where Δxi=[xi-xi-1]
The lower Riemann sum = i=(1[itex]\rightarrow[/itex]n) [itex]\sum[/itex]miΔxi where Δxi=[xi-xi-1]
Mi=sup[f(xi): x[itex]\in[/itex][xi, xi-1]
mi=inf[f(xi): x[itex]\in[/itex][xi, xi-1]
OK, let [itex]c_i[/itex] (resp. [itex]d_i[/itex]) be the element of [itex][x_i,x_{i+1}][/itex], where f reaches his maximum (resp. minimum).
We know that
[tex]\sum_{i=1}^n (f(c_i)-f(d_i)) \Delta x_i<\varepsilon[/tex]
Now, can you prove that [itex]\varphi\circ f[/itex] also reaches his maximum (resp. minimum) in [itex]c_i[/itex] (resp. [itex]d_i[/itex])??
If that were true, then we have to do something with
[tex]\sum_{i=1}^n (\varphi (f(c_i))-\varphi(f(d_i))) \Delta x_i<\varepsilon[/tex]
Can't we just say that since [itex]\phi[/itex] is monotone increasing, that we know that [itex]\phi[/itex](f(ci)) (resp. [itex]\phi[/itex](f(di))) is where [itex]\phi[/itex] reaches its maximum (resp. minimum)?
Thus, 0[itex]\leq[/itex]l [itex]\phi[/itex](f(ci) - [itex]\phi[/itex](f(di)) l [itex]\leq[/itex]2K?
I don't see where this comes from or why it is necessary.
But, basically, we have something of the form
[tex]\sum_{i=1}^n {(\varphi(f(c_i))-\varphi(f(d_i)))\Delta x_i}[/tex]
and you must associate this with
[tex]\sum_{i=1}^n {(f(c_i)-f(d_i))\Delta x_i}[/tex]
Do you have any result that associates [itex]\varphi(f(c_i))-\varphi(f(d_i))[/itex] with [itex]f(c_i)-f(d_i)[/itex]?? (use that [itex]\varphi[/itex] is differentiable)
  • · Replies 22 ·
