Show that differentiable curves have measure zero in R^2
The discussion revolves around demonstrating that differentiable curves in R² have measure zero. The original poster presents a problem involving a differentiable curve parametrized by arc length and seeks to establish certain inequalities and properties related to the curve's length and area coverage by open discs.
  • Participants explore the application of the mean value theorem for vector-valued functions and discuss the implications of using integrals to establish the required inequalities. Questions arise regarding the proper use of theorems and definitions relevant to measure theory and integration.
Some participants have provided suggestions for alternative approaches, particularly involving integrals, while others are clarifying concepts related to measure theory. There is an ongoing exploration of how to apply these ideas to the original problem without reaching a consensus on the final approach.
Participants note the need for clarity on the definitions of measures and theorems being referenced, indicating a potential gap in understanding that may affect their reasoning. The discussion also highlights the original poster's uncertainty about how to proceed with part (b) of the problem.
Demon117
(a) Let [itex]\alpha:I=[a,b]→R^2[/itex] be a differentiable curve. Assume the parametrization is arc length. Show that for [itex]s_{1},s_{2}\in I, |\alpha(s_{1})-\alpha(s_{2})|≤|s_{1}-s_{2}|[/itex] holds.
(b) Use the previous part to show that given [itex]\epsilon >0[/itex] there are finitely many two dimensional open discs [itex]B_{\epsilon}(x_{i}), i=1,..,n[/itex] such that [itex]\alpha (I)\subset \cup _{i=1..n}B_{\epsilon}(x_{i})[/itex] and [itex]\sum_{i}Area(B_{\epsilon}(x_{i}))<\epsilon[/itex].
2. The attempt at a solution
(a) For this I made an argument using the mean value theorem for equality. For all [itex]s\in I[/itex], we have [itex]|\alpha '(s)|=1[/itex] since the curve is parametrized by arc length. Then, given some [itex]s_{o}\in (s_{1},s_{2})[/itex] for some [itex]s_{1},s_{2}\in[a,b][/itex] we have by the mean value theorem
[itex]\frac{\alpha(s_{1})-\alpha(s_{2})}{s_{1}-s_{2}}=\alpha'(s_{o})[/itex]
whereby,
[itex]\frac{|\alpha(s_{1})-\alpha(s_{2})|}{|s_{1}-s_{2}|}=1[/itex], so equality holds.
I am unsure how I should show that it has to be less than. I will have to think of this more. What I am really stuck on is how to even attempt part (b). Any suggestions would be very appreciated.
You seem to be applying the mean-value theorem like ##\alpha## was a function in one-variable. But in reality, it is a vector-valued function. Do you know the mean-value theorem for vector-valued functions?
Actually, I hadn't caught that until you pointed it out. I am not familiar with that theorem.
OK, doesn't matter, you can do it with integrals easily.
LeTake ##v## a vector with ##\|v\|= 1##. Show that
[tex]\|\alpha(b) - \alpha(a)\| = \int_a^b \alpha^\prime(t)\cdot v ~dt \leq \int_a^b\|\alpha^\prime(t)\|dt[/tex]
then take a suitable ##v## to prove your conjecture.
Ok, so I have taken care of that. Thanks for the suggestions, they were quite helpful. I have also shown the second part quite well enough. The only thing that remains is the following:
(c) If h is a bounded continuous function on [itex]R^{2}[/itex], using the previous part, give a reasonable argument as to why
[itex]∫_{\alpha}h dx dy=0[/itex]
should hold.
The thought I had was to use the change of variables theorem to integrate over a larger set containing [itex]\alpha(I)[/itex]. But I suppose you would have to define some local parametrization in [itex]R^2[/itex], unless you took the union of the disks as in part (b) to be the locally parametrized surface? That seems really odd though and doesn't make a lot of sense. . .
So in general, if ##E## is any set of measure ##0## and if ##f## is some function (let's say continuous), then
[tex]\int_E f = 0[/tex]
Try something like
[tex]\left|\int_E f\right| \leq \int_E |f|\leq \int_E \textrm{sup}(|f|)\leq \lambda(E)\textrm{sup}(|f|)[/tex]
Try something like
What is the significance of [itex]\lambda(E)[/itex] in this case? Could you define that for me? It seems rather arbitrarily chosen to me.
The function ##\lambda## is the Lebesgue measure. Have you not seen this?
Yes, now that makes sense. Our notation uses m rather than [itex]\lambda[/itex]. I appreciate your help.
