Show that F'(x) exists for all x [tex]\in[a,b] [/tex]
  • Thread starter Thread starter irresistible
The problem involves the function F(x) defined piecewise, where F(x) = x² sin(1/x²) for 0 < x ≤ 1 and F(x) = 0 for x ≤ 0. The goal is to show that F'(x) exists for all x in the interval [a, b], while also demonstrating that F' is not integrable over [0, 1].
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to prove the existence of the derivative, particularly at x = 0, and question whether standard differentiation techniques suffice or if deeper analysis is required. There is mention of limits to establish the existence of F'(0). Some participants suggest that F'(x) is defined for x ≠ 0 and explore the implications of the derivative's behavior as x approaches 0.
The discussion is ongoing, with participants providing insights into the differentiation process and the behavior of F'(x). There is recognition of the need to show that F'(x) is unbounded, with some participants proposing specific values of x to illustrate this point. However, there is no explicit consensus on the final conclusions regarding integrability.
Participants are navigating the complexities of piecewise functions and the implications of differentiability at critical points. The discussion includes considerations of limits and the behavior of trigonometric functions as arguments approach certain values.
irresistible
Consider
F(x) = x2 sin(1/x2) if 0<x[tex]\leq1[/tex]
and = 0 if x[tex]\leq0[/tex]
Show that F'(x) exists for all x [tex]\in[a,b][/tex] but that F':[0,1] [tex]\rightarrow1[/tex] is not integrable.
So we have to show we do not have F(1)-F(0) = [tex]\int[/tex] F'(x)dx
(integral going from 0 to 1)
I'm having trouble proving this statement.
Where should I start?
To show that F'(x) exists, should I just take the derivative or do I have to go under some long theorems of analysis to PROVE?
Thanks in advance.:shy:
Most likely you'll have to actually *prove* that this derivative exists - it clearly exists for all x other than 0 because [tex]x^{2}sin(\frac{1}{x^{2}})[/tex] is the composition of differentiable functions. The only tricky part is whether F'(0) exists. To show that it does indeed exist you'll need to show that the following limit exists:
[tex]\lim_{h\to 0}\frac{f(h) - f(0)}{h}[/tex]
But this just equals
[tex]\lim_{h\to 0}\frac{h^{2}sin(\frac{1}{h^{2}})}{h} = lim_{h\to 0}hsin(\frac{1}{h^{2}}) = 0[/tex]
Then by application of the product rule and the chain rule,
[tex]F'(x) = 2xsin(\frac{1}{x^{2}}) - \frac{2cos(\frac{1}{x^{2}})}{x^{2}}[/tex]
if x is anything other than 0, and 0 if x=0. So all you need to show is that the above function is unbounded and it will consequently not be integrable.
right,
But I think you made a little mistake with differentiation,
I think it will be:
F'(x)= 2x sin(1/x2) - 2cos(1/x2)/ x
Which still, limits exists.
But How do I prove that F'(x) is unbounded?
Take [itex]x= 1/\sqrt{2n\pi}[/itex]. Then [itex]1/x^2= 2n\pi[/itex] so [itex]sin(1/x^2)= 0[/itex] and [itex]cos(1/x^2)= 1[/itex]. [itex]F'(x)= F'(1/\sqrt{2n\pi})= -2\sqrt{2n\pi}[/itex]. x will go to 0 as n goes to infinity. What happens to F'(x)?
F'(x) will be Undefined as x approaches zero [tex]\rightarrow[/tex] unbounded [tex]\rightarrow[/tex] non integrable ?
HallsofIvy just defined F'(x) above, so it *will* be defined; however, as n-->infinity, F'(x) also goes to infinity and this implies that the derivative is unbounded.
Also, thanks for pointing out my mistake; I was in an Econ class :P
  • · Replies 17 ·
