Show that if T^2 = 0 then I - T is one-to-one and onto
  • Thread starter Thread starter AzwinAwin
The discussion revolves around proving that if T^2 = 0 for a linear transformation T on a vector space V, then the transformation I - T is both one-to-one and onto, where I denotes the identity transformation.
  • Participants explore the relationship between the transformations and question the validity of applying the binomial formula in this context. Some suggest examining the implications of the product of linear maps being invertible.
There are various lines of reasoning being explored, including the relationship between T and the identity transformation, and the implications of T^2 = 0. Some participants express confusion about the hints provided, while others clarify misconceptions regarding the properties of linear transformations.
Some participants question the assumptions about T and its implications, particularly regarding whether T must equal 0 if T^2 = 0. There is also mention of the need for further understanding of operators in the context of linear transformations.
AzwinAwin
Member warned to post homework questions in a homework section
Let V be a vector space and T:V->V a linear transformation. Show that if T^2 = 0 then I - T is one-to-one and onto. As I denoted as the identity transformation.
can i relate it with (1-t)(1+t)=(1-t^2) when i do the proving ? how?
You've found the basic idea behind it. But is it also true, that (A-B)^2 = A^2 - 2AB +B^2 for any linear A,B : V → V? When and why can you apply the binomial formula?
Try using this with what you have: If the product of two linear maps is invertible, then each of those maps is invertible.
BiP
your hints re very helpful. thanks a lot.
I'm sorry.
I don't think so the hint help me to solve the question.
Can someone explain more clearly?
Abhineshwary said:
I'm sorry.
##(I-T)(I+T)=I²-T²=I-0=I##
and now use @Bipolarity 's remark.
(A- B)^2= (A- B)(A- B)= A^2- AB- BA+ B^2. That is NOT generally A^2- 2AB+ B^2 because, for linear transformations, it is NOT general y true that AB= BA.
The binomial formula assumes that the values are commutative under multiplication so that the product of the same number of terms in any order can be combined.
... which for linear functions in general is only true to multiples of 1.
a function is 1-1 and onto iff it has an inverse. you have proved that 1-t has as inverse 1+t. qed. what can you say if T^3 =0? or if T^n = 0?
I am kind of interested in what the answer to this would be.
I would have said that because T^2 = 0, T must also equal 0. Therefore, 1 - T = 1 - 0 = 1.
x/y = x:y
1/1 = 1:1
Is this process a valid proof for this kind of question? Or am I completely off?
x/y = x:y
1/1 = 1:1
No, for operators, T^2 = 0 doesn't imply that T must also equal 0
An example, take the following operator ##T: \mathbb R² \to \mathbb R²: (x,y) \mapsto (0,x)##
##T(x,y)=(0,x)##, ##T²(x,y)=T(0,x)=(0,0)##
So ##T \neq 0##, but ##T²=0##.
Also note: ##(I-T)(x,y)=I(x,y)-T(x,y)=(x,y)-(0,x)=(x,y-x) \neq I(x,y)##
Okay, thank you. I am unfamiliar with what operators are or how they work, so I sort of just tried to solve it as a regular equation. I suppose I will need to go a research these operators further now.
Okay, thanks a lot everyone!
  • · Replies 24 ·
