Show that the given function is continuous
27 replies · 3K views
chwala
Show that the function ##f :\mathbb{C} → \mathbb{C} ## defined by ##f(z) = {\sqrt 3} i^2 |z|## is a continous function.
complex numbers.
Refreshing... going through the literature i may need your indulgence or direction where required. ...of course i am still studying on the proofs of continuity...the limits and epsilons... in reference to continuity of functions...
From my reading, A complex valued function is continous if and only if both its real part and imaginary part are continous.
Firstly
##f(z)= x+iy = -\sqrt 3 x^2 -\sqrt 3 y^2 i=u(x,y)+iv(x,y)##,that is from the concept under Cauchy-Riemann equations. Therefore, ##u(x,y)=-\sqrt 3 x^2## and ##v(x,y)=-\sqrt 3 y^2## of which both ## u(x,y)## and ##v(x,y)## are continous.
Hill said:
How did you get this:
##-\sqrt 3 x^2 -\sqrt 3 y^2 i##
##|z| = |x+iy| = x^2+y^2## unless i am missing something...
It does not answer my question AND this is incorrect.
okay...am back to the drawing board...later. I am missing the square root sign...typo...let me take a break.
##\sqrt{x^2 + y^2}##
From where i left, i have
##f(z)=\sqrt 3 ⋅ i^2|z|=-\sqrt 3 |x+iy| = -\sqrt 3 {\sqrt{x^2 + y^2}}##
We know that ##z=x+iy## therefore using the cauchy Riemann equations we shall
let ##u(x,y) =x## and ##v(x,y)=iy##
then,
##u_x= -\dfrac{\sqrt{3}}{2} ⋅(x^2+y^2)^{-0.5}⋅ 2x= -\dfrac{2x\sqrt{3}}{2\sqrt{x^2+y^2}} =-\dfrac{\sqrt{3}x}{\sqrt{x^2+y^2}}## and
##u_y= -\dfrac{\sqrt{3}}{2}⋅ (x^2+y^2)^{-0.5} ⋅2y=-\dfrac{2y\sqrt{3}}{2\sqrt{x^2+y^2}}=-\dfrac{\sqrt{3}y}{\sqrt{x^2+y^2}}##
##u(x,y)## is continous and ##v(x,y)## is continous and therefore ##f(z)## will be continous.
I don't understand what it means and don't see you using it anywhere.
chwala said:
Homework Statement: Show that the function ##f :\mathbb{C} → \mathbb{C} ## defined by ##f(z) = \sqrt 3 i^2 |z|## is a continous function.
Relevant Equations: complex numbers.
Use the definition of continuity directly. [itex]f : \mathbb{C} \to \mathbb{C}[/itex] is continuous at [itex]w \in \mathbb{C}[/itex] iff for every [itex]\epsilon > 0[/itex] there exists [itex]\delta > 0[/itex] such that for every [itex]\mathbb{z} \in \mathbb{C}[/itex], if [itex]|z - w| < \delta[/itex] then [itex]|f(z) - f(w)| < \epsilon[/itex]. Consider that [tex] |z| = |z - w + w| \leq |z - w| + |w|[/tex] and [tex] |w| = |w - z + z| \leq |w - z| + |z|.[/tex] Hence [tex] ||z| - |w|| \leq |z - w|.[/tex]
Can I let ##w=0##. This is an area I need to study...and are you implying one cannot use the Cauchy Riemann equations?
No. The only requirement on w is that ##|z-w|<\delta##.it should be clise to whatever z you want to show continuity at.
Alternatively just show that the preimage of any open set is an open set. That should be pretty straightforward.
Alternatively, we see that ##f## is a composition of polynomial and modulus, both of which are continuous.
Cauchy-Riemann stuff is relevant for complex differentiability.
You don't have braces around the square root radicand.
Do you mean this -- ##\sqrt 3 \cdot i^2 |z|##?
Or this -- ##\sqrt{3 i^2}|z|##?
The first would simplify to ##-\sqrt 3 |z|## and the second would simplify to ##\sqrt{-3}|z| = i\sqrt 3 |z|##.
It should be very simple to show continuity for either one.
Regarding TeX, keep in mind that if what comes after an operator is a single character, you can omit braces, but if what follows is two or more characters, braces are necessary.
For example, I can omit braces to write ##x^2## (unrendered this is ##x^2##), but braces are needed for ##x^{-1}## (unrendered: ##x^{-1}##). Without braces, this comes out as ##x^-1##; i.e., the 1 doesn't get rendered as a superscript.
If your ##i^2## refers to the Complex number ##i##, then your map is actually ##\mathbb R##- valued. As such, it's a product of continuous functions.
yes, the ##i## refers to the complex number.
The first one...
chwala said:
The first one...
Then you want to write it as ##\sqrt{3 i^2}|z| = \sqrt{-3}|z| = i\sqrt 3 |z|##. I assume you know how to right click on the above to show the TeX that I wrote.
Edit: I mistook what the first one was. That one should have been written as ##-\sqrt 3 i^2|z| = -\sqrt 3 |z|##.
Orodruin said:
The first one was this:
Yes @Orodruin , sorry I was unable initially to put parenthesis...but @Mark44 advised how to do it .. I didn't want to amend original post following the threads...
forgive me if I misunderstand the question. either you want to know how to give a formal proof of continuity, or to understand why it is true. In my opinion, if you understand why, you have a better chance of giving a proof, so I address that.
Continuity means that whenever the inputs are close, the outputs are also close.
'first consider the function |z|. Note that |z| is the distance from z to the origin. thus one must show that if z is close to w, then z is almost as close to the origin as w. This is called the triangle inequality.
I.e. the distance from z to the origin is less than the sum of the distance from w to the origin plus the distance from z to w. Thus if z is near w, then z is almost as close to the origin as w.
The question is a past exam question -Analysis paper. The question is written as it is on the paper.
forgive me, I assumed you wanted to understand it. that is what I am addressing.
I really appreciate it @mathwonk ...my undergraduate professors rushed on the chapters to do with Analysis plus I didn't put much work afterwards..I just have to self study... Cheers man.
This is a very strange question! Clearly the constant ##\sqrt{3}i^2## plays no role, why is it discussed so much! So the question is to show that ##f(z)=|z|## is continuous. Isn't this obvious given what continuous means! May be you can start with the definition of continuous you use.
If your function is ##f(z)=|z|##, then you can check whether the inverse image of an open set is open. It will depend on your domain, range. In this case, ##|z|## is Real-valued. An open interval##(a,b)## would have as an inverse image all circles of radius ##r; a<r<b##.
I tried to hint at this, but OP didn't seem to bite:
It should be added that the shape of the preimage is called an annulus.
I am following the steps slowly 😄...
