Show that the line state is separable
1 reply · 1K views
maxi123
Consider the "line" state ##rho=\frac{1}{d}\sum_{k=0}^{d-1}P_{0,k}##. Show for arbitrary d that the state is separable.
##P_{k,j}=|\Omega_{k,j}><\Omega_{k,j}|## with ##|\Omega_{k,j}>=(W_{k,j}\otimes \mathbb{1})\sum_{s=0}^{d-1}|s,s>##. ##(W_{k,l}## are Weyl-Operators)
I introduced the unitary transformation ##U=U_a \otimes U_b## with ##(U_a\otimes 1):\;|s,s> \rightarrow\,\frac{1}{\sqrt{d}}\sum_t \omega^{ts}|t,s> ## und ##(1\otimes U_b):\;|s,s> \rightarrow\,\frac{1}{\sqrt{d}}\sum_t \omega^{-ts}|s,t> ## ##(\omega=e^{2\pi i/d}##) and let it act on the state in the following way ##\frac{1}{d}\sum_{k=0}^{d-1}UP_{0,k}U^\dagger##. By doing so i showed that my density matrix is diagonal and therefore the state is separable. I'm not sure if I can do this transformation (under which the Bellstates are invariant) without changing the separablity/entanglement of the state.
Yes, you can do this transformation without changing the separability/entanglement of the state. This is because the unitary transformation preserves the entanglement of the state. In particular, if a state is separable before the transformation, it will remain separable after the transformation.
