Show that transformation is Canonical
  • Thread starter Thread starter Gunthi
    Transformation
The discussion centers on proving that the transformation defined by Q=qe^{\gamma t} and P=pe^{-\gamma t} is canonical, utilizing the Hamiltonian H=\frac{p^2e^{-2\gamma t}}{2m}+\frac{m\omega^2q^2e^{2\gamma t}}{2}. Participants explore the necessary conditions for a transformation to be canonical, referencing the generating function F_2=qPe^{\gamma t} and the use of Poisson brackets. The conclusion emphasizes that demonstrating [Q,P]_{q,p}=1 is sufficient for establishing the transformation as canonical.
  • Understanding of Hamiltonian mechanics and canonical transformations
  • Familiarity with Poisson brackets and their properties
  • Knowledge of generating functions in classical mechanics
  • Ability to manipulate Hamilton's equations
  • Study the derivation and implications of Hamilton's equations
  • Learn about the properties and applications of Poisson brackets
  • Explore the concept of generating functions in more depth
  • Investigate canonical transformations and their significance in classical mechanics
Students and professionals in physics, particularly those focused on classical mechanics, Hamiltonian dynamics, and mathematical physics. This discussion is beneficial for anyone looking to deepen their understanding of canonical transformations and their applications.
Gunthi
Given the transformation Q=qe^{\gamma t} and P=pe^{-\gamma t} with the Hamiltonean H=\frac{p^2e^{-2\gamma t}}{2m}+\frac{m\omega^2q^2e^{2\gamma t}}{2} show that the transformation is Canonical
I know that the condition for a transformation to be canonical is \sum_i p_i\dot{q_i}-P_i\dot{Q_i}=H-K+\frac{dF_2}{dt} but don't know what to do with it...
I've managed to prove from \frac{dF_2}{dq_i}=p_i and \frac{dF_2}{dP_i}=Q_i that F_2=qPe^{\gamma t}.
I have another question related to this problem. Does having the generating function guarantee that the coordinate transformation associated with it is canonical? Or is it a necessary but not sufficient condition?
I know a way to check out whether the transformation is canonical but it doesn't involve the Hamiltonian.
If you know Poisson's brackets, if you can show that [Q,P]_{q,p}=1 then you'd be done.
To answer your question "Does having the generating function guarantee that the coordinate transformation associated with it is canonical? Or is it a necessary but not sufficient condition?", I'm not 100% sure but I'd say yes (99% sure).
I've been messing around with the coordinates and got this:
If we have a general invertible transformation of the type Q=Q(q,p,t)\Leftrightarrow q=q(Q,P,t) and P=P(q,p,t)\Leftrightarrow p=p(P,Q,t) then the following is true:
\begin{matrix}
\dot{q}=\frac{\partial q}{\partial Q}\dot{Q}+\frac{\partial q}{\partial P}\dot{P}\\
\dot{p}=\frac{\partial p}{\partial Q}\dot{Q}+\frac{\partial p}{\partial P}\dot{P}
\end{matrix}
From Hamilton's eqs we have (inserting the given coordinate transformations):
\begin{matrix}
\dot{q}=\frac{\partial H}{\partial p}=\frac{\partial H}{\partial P}e^{-\gamma t}=\frac{\partial q}{\partial Q}\dot{Q}\Rightarrow \frac{\partial H}{\partial P}=\dot{Q}\\
\dot{p}=-\frac{\partial H}{\partial q}= -\frac{\partial H}{\partial Q}e^{\gamma t}=\frac{\partial p}{\partial P}\dot{P}\Rightarrow -\frac{\partial H}{\partial Q}=\dot{P}
\end{matrix}
The form of Hamilton's equations is the same but from what I've seen in Goldstein, when one makes a canonical transformation the form is preserved not for the initial Hamiltonian but for the "Kamiltonian" K=H+\frac{dF_2}{dt} i.e.
\begin{matrix}
\frac{\partial K}{\partial P}=\dot{Q}\\
-\frac{\partial K}{\partial Q}=\dot{P}
\end{matrix}
and because I've already proved that there exists a function F_2 I get the feeling that the proof is not correct. What am I doing wrong here?
Thanks for the advice! Actually, calculating with the Poisson brackets is another part of this problem, but instead it is asked to evaluate [Q,Q],[P,P],[Q,P],[q,H],[p,H] without explicit calculation.
For the first two the answer is obviously zero because of the crossed derivatives, the third one, being this a suposedly canonical transformation is 1 and for the last two I'm having a little bit of a problem because if I use \frac{du}{dt}=[u,H]+\frac{\partial u}{\partial t} on q and p I am not sure if it is \frac{dq}{dt} or \frac{\partial q}{\partial t} (for p too) that is zero. I know, this is a dumb question, but when a function depends only on t does the partial derivative looses its meaning?
Ok, since you found out F_2 then I think you are done. Let me give you a useful link: http://books.google.com.ar/books?id...a transformation is canonical poisson&f=false.
About the Poisson's bracket question, you are right for the 3 first. As for the last 2 I must say I'm not sure; I'd consult Landau's book on classical mechanics first and then other books.
About your question about partial derivatives; when you have a function of only 1 variable a partial derivative is the same as a total derivative.
But I doubt q only depends on t.
Thanks for the book! I tried to see if there was anything in Landau that could help but didn't find it yet. Anyhow, I found this http://solar.physics.montana.edu/dana/ph411/p_brack.pdf and I can't figure out why, in page 2 after equation (3) \frac{\partial q_1}{\partial t}=0. Isn't q_1 also a function of t? Why isn't \frac{dq_1}{dt} also zero?
I'm in the same boat as you. I do not understand why it is so.
For sure, q_1 isn't a constant of motion, otherwise we'd have \{ q_1 , H \}=0. So there's indeed a dependency of q_1 with respect to time. Thus, I do not understand how it's possible that \frac{\partial q _1 }{\partial t } =0.
I wish someone could enlighten us!
I'm just posting this so that the thread doesn't seem closed.
