Show Wolfram Alpha's answer is equivalent to my answer.
4 replies · 2K views · last reply
jlmccart03
Integrate x2(2+x3)4dx.
Show that Wolfram Alpha's answer is equivalent to your answer.
No equations besides knowing that the integral of xpower is 1/power+1 * xpower + 1
So I have the answer to the integral by hand as (2+x3)5)/15 + C.
When I go to Wolfram Alpha it gives x15/15 + 2x12/3 + 8x9/3 + 16x6/3 + 16x3/3 + C
I really truly have no idea how these two are the same. I tried multiple types of manipulation to my answer, but I am completely lost on where basically every factor comes from besides the first x15/15.
Any help will be appreciated!
Your answer is correct.
They expanded ##(2+x^3)^5## as ##x^{15} + 10 x^{12} + 40 x^9 + 80 x^6 + 80 x^3 + 32## (this can be found using Newton's binomium). Thus, after dividing both sides with 15, we get:
##\frac{(2+x^3)^5}{15} = x^{15} /15 + 2x^{12}/3 + 8x^9/3 + 16x^6/3 + 16x^3/3 + 32/15##
However, the constant in the primitive function does not matter (as we write ##+ c## anyway), so we can drop the ##32/15## safely.
However, the constant in the solution of an indefinite integral does not matter, so we can drop the ##32/15## safely.
Ok, So they simply expanded the numerator using a thing called Newton's binomium? I will do some research on that, but I do not think we have ever learned what Newton's Binomium is. Thanks for explaining how this worked. I was completely lost on how it worked, but now it seemed relatively simple.
Math_QED said:
You could just have done the multiplications by hand using the distribiutivity property, but the Binomial theorem would be faster:
https://en.wikipedia.org/wiki/Binomial_theorem
OHHHHHHH that is what that is called. Ok, so I have done that before. Totally did not think of that as a solution. Thanks for the link, totally forgot that I could use that method.
