Showing fourier coefficients reduce mean square error best
3 replies · 5K views · last reply
eschiesser
So I'm supposed to show that a finite Fourier approximation is the optimal approximation for a given function.
I am to suppose we have a given set of functions [tex]\phi _k(x),k=1,2,\text{...}N[/tex] defined on [tex]a\leq x\leq b[/tex].
They are orthogonal [tex]\int _a^b\phi _m(x)\phi _n(x)dx=0 \text{ for } m\neq n[/tex]
and are normalized [tex]\int _a^b\left[\phi _m(x)\right]{}^2dx=1[/tex]
a general approximation for f(x) in terms of these N functions is
[tex]f_{\text{app}} (x)=\sum _{m=1}^N \gamma _m\phi _m(x)[/tex]
One possible choice of coefficients is the Fourier coefficients defined by:
[tex]f_m=\int _a^bf(x)\phi _m(x)dx[/tex]
The mean square error is defined as:
[tex]E=\int_a^b \left[f(x)-f_{\text{app}} (x)\right]{}^2 \, dx=\int_a^b \left[f(x)-\sum _{m=1}^N \gamma _m\phi _m(x)\right]{}^2 \, dx[/tex]
I am supposed to show that the Fourier coefficients would be the optimal choice of [tex]\gamma _m[/tex] to minimize E
Thus far, I have carried out the square in the integrand of the error term, used the idea of orthogonality, and substituted the Fourier coefficients in for gamma, but from there I am stuck! Here is what I have...
[tex]E=\int _a^b[f(x)]^2dx-2\int _a^bf(x)\left[\sum _{m=1}^N \int _a^bf(x)\phi _m(x)dx\right]\phi _m(x)dx+\left[\sum _{m=1}^N \int _a^bf(x)\phi _m(x)dx\right]{}^2[/tex]
From here, I am stuck! is there some kind of simplification that I am missing? this is very frustrating. Any help/nudge would be appreciated.
-Eric
Double check your squaring of [tex]\left[f(x)-\sum _{m=1}^N \gamma _m\phi _m(x)\right]{}^2[/tex] because your last formula for E looks suspect. Did you confuse f_m and gamma_m?
The key trick (eventually) is to use [tex]-2\gamma_m f_m+\gamma_m^2 = -f_m^2 + (f_m - \gamma_m)^2[/tex]
if I am understanding the problem correctly, which is not an assumption I would bet any substantial amount of money on, I thought that the point was to show that [tex]f_m[/tex] is the best substitution for [tex]\gamma_m[/tex], e.g. show that [tex]f_m=\gamma_m[/tex] reduces E better than any other substitution for [tex]\gamma_m[/tex].
So I everywhere I see [tex]\gamma_m[/tex] i want to substitute the expression for [tex]f_m[/tex] and show somehow that this is minimizes E, correct?
No, wait until the end to imagine replacing gamma_m with f_m. Do the algebra I suggested and you should end up with an expression
E = expression involving both gamma_m and f_m
If you do enough algebra (correctly), you will see that this E is clearly minimized when gamma_m = f_m.
Sorry I'm being vague. It's not really too hard.
