High School Is the sign of the square root dependent on the argument inside it?
The discussion centers on whether the sign of the square root is dependent on the argument inside it. It is established that while the principal square root is always positive, there are indeed two roots for any given number: the principal root and its negative counterpart. For example, both 2 and -2 are roots of 4, while for -4, the roots are 2i and -2i. The conversation suggests that the choice of sign for the square root is not arbitrary but rather defined by mathematical principles. Ultimately, the sign of the square root does depend on the nature of the argument, reinforcing the distinction between principal and secondary roots.
jk22
Could it be said that since ##a=A(f(x))\sqrt{f(x)}##, with ##A(x)\in\{1,-1\}## then ##a^2=f(x)##,, that ##a## is the square root of ##f(x)## ?
In other words could the sign of the root depend on the argument inside it ?
Else it would have to be chosen by human free will and to be blocked for the rest of the calculation ?
No, the principal square root of a number is positive real or positive imaginary based on whether the argument inside is a positive or negative number.
However, we realize that there are two roots the principal root and -1 times the principal root.
As an example, both 2 and -2 are roots of the square root of 4. 2 is the principal root and -2 is another root since (-2)*(-2) = 4 just as 2 * 2 = 4
In the case of a negative -4 then the roots are 2i and -2i
More fun stuff here:
https://en.wikipedia.org/wiki/Square_root
Likes HallsofIvy
Relativistic Momentum, Mass, and Energy Momentum and mass (...), the classic equations for conserving momentum and energy are not adequate for the analysis of high-speed collisions. (...) The momentum of a particle moving with velocity ##v## is given by $$p=\cfrac{mv}{\sqrt{1-(v^2/c^2)}}\qquad{R-10}$$ ENERGY In relativistic mechanics, as in classic mechanics, the net force on a particle is equal to the time rate of change of the momentum of the particle. Considering one-dimensional...
  • · Replies 21 ·
  • · Replies 45 ·
