Undergrad Significance of the Exchange Operator commuting with the Hamiltonian
sophiatev
In an Introduction to Quantum Mechanics by Griffiths (pg. 180), he claims that
"P and H are compatible observables, and hence we can find a complete set of functions that are simultaneous eigenstates of both. That is to say, we can find solutions to the Schrödinger equation that are either symmetric (eigenvalue +1) or antisymmetric (eigenvalue -1) under exchange"
I understand why commuting (or as he calls them, compatible) observables share a common eigenbasis. What I don't see is why P, the exchange operator, and H, the Hamiltonian, need to commute for the second sentence to be true. If P is an observable, then supposedly it is a Hermitian operator whose eigenstates span the L2 Hilbert space. It's true that for some Hermitian operators (like the position one, for example), the eigenstates of the operator do not themselves lie in L2 Hilbert space. That being said, I can imagine other ways of showing that the eigenstates of P lie in L2 Hilbert space and thus constitute valid solutions to Schrödinger's equation. I feel like there's something else he's trying to show here, but I'm not exactly sure what. What is he trying to show by stating the P and H commute?
The only eigenvalues of P are +1 and -1. So any state that is an eigenstate of both P and H must have one of those two eigenvalues when operated on by P.
Sure, I get that much. And I get that since the common eigenbasis is composed of vectors that are eigenvectors of both P and H, every vector in that basis when operated on by P will yield either +1 or -1. But I still don't understand what the significance is of that common eigenbasis existing in the first place.
What do you mean by "the significance" of the common eigenbasis existing? You say you understand why commuting observables have a common eigenbasis, and you say you understand why any state in the common eigenbasis of P and H has eigenvalue +1 or -1 when operated on by P. What else is there to understand? What's the problem?
PeterDonis said:
What do you mean by "the significance" of the common eigenbasis existing? You say you understand why commuting observables have a common eigenbasis. What don't you understand? What's the problem?
I don't understand why it was necessary to show the existence of the common eigenbasis to show that
"we can find solutions to the Schrödinger equation that are either symmetric (eigenvalue +1) or antisymmetric (eigenvalue -1) under exchange". Why does this directly follow from the existence of the common eigenbasis? I guess this is why I brought up the position operator. Its eigenbasis spans L2 Hilbert space, and so we can construct any solution to the Schrödinger equation using its eigenvectors. But its eigenvectors don't themselves lie in L2 Hilbert space, so they aren't solutions. There seems to be something significant about the fact that the eigenbasis in this case consists of eigenvectors of H as well. I just don't see the connection between the eigenbasis being composed of eigenvectors of H (and P) and the existence of eigenvectors of P that are solutions to Schrödinger's equation.
Is the problem that the phrase "solutions to the Schrödinger equation" was used without qualification, instead of "solutions to the Schrödinger equation that are eigenstates of the Hamiltonian"? If so, I believe that by "Schrödinger equation" here Griffiths means the time-independent Schrödinger equation, i.e., the eigenvalue equation for H. So any solution of this equation is automatically an eigenstate of H.
No, it doesn't, because, as you yourself say just a little further on, it's eigenfunctions aren't even in the L2 Hilbert space. You can't span a Hilbert space with functions that aren't even in the space. Some sources will be sloppy and talk as though you can, but that's sloppy and incorrect.
How else would you prove this? It can't simply be assumed. The argument using the exchange operator is probably the simplest proof, but you need some sort of proof.
Ahhh, I see. So is the claim that since all the eigenstates of H are solutions to the time-independent Schrödinger, the common eigenbasis necessarily consists of solutions to the (time-independent) Schrödinger equation?
That's the way I'm reading it, yes.
  • · Replies 67 ·
