Significant figures vs precision (I think)
The discussion focuses on calculating the frequency heard by a receiver moving at 5.0 m/s towards a sound source emitting a frequency of 3000 Hz, using the Doppler effect formula. The speed of sound is assumed to be 343 m/s at 20°C. The calculated frequency is 3043.731 Hz, but rounding to significant figures leads to confusion, as the result appears to revert to 3000 Hz. The ambiguity arises from the number of significant figures in the original frequency, which affects the accuracy of the final answer.
  • Understanding of the Doppler effect and its formula: Freceiver = Fsender((V + Vreceiver)/V)
  • Knowledge of significant figures and their application in scientific calculations
  • Familiarity with basic physics concepts, particularly sound waves and speed of sound
  • Ability to perform unit conversions and calculations involving decimals
  • Study the implications of significant figures in scientific calculations
  • Learn how to apply the Doppler effect in various scenarios, including light and sound
  • Explore the concept of measurement uncertainty and its impact on calculations
  • Investigate advanced applications of the Doppler effect in fields like astrophysics and radar technology
Students in physics, educators teaching the Doppler effect, and anyone interested in understanding the implications of significant figures in scientific calculations.
gijoel
I've got a doppler shift question about calculating the frequency heard by a receiver moving 5.0m/s towards a sound source that is emitting 3000Hz sound. I assumed speed of sound is 343 m/s for an air temperature of 20C.
Freceiver = Fsender((V + Vreceiver)/V) Where V is speed of sound in air
After calculating the sound I get 3000Hz x (348/343)
Which equals 3000hz x 1.015
=3043.731...Hz
If I round off to one or two significant digits like the problem states then I get 3000Hz. Which doesn't make sense. What am I missing here? Is there some rule the over rides significant digits for these types of answers?
The number of significant figures in the given frequency of 3000 Hz is ambiguous. If you assume it has at least 3 significant figures, then you can keep 3 significant figures in the result of the calculation 3000 Hz x (348/343).
If the 3000 Hz has two or less significant figures then you would get 3000 Hz for the answer. It just means that to two significant figures, there is no difference between the source frequency and the doppler shifted frequency.
the point about significant figures, is that if you put data of limited accuracy into the equation; you get an answer of limited accuracy.
To give a more accurate answer would be wrong (because, say, your 5.0m/s could mean 4.95m/s or 5.04 m/s - you don't know - all you can assume is that it was measured with an instrument of limited accuracy, so you cannot assume more accuracy).
I would give the full calculation and write the answer as
blah blah = 3043.731 Hz
which is
3.0 x 10^3 Hz to two significant figures
3 x 10^3 Hz to one significant figure (assuming given frequency is correct to one sig fig)
can't go wrong there - its not clear if the given frequency is correct to 1,2,3 or 4 figures ? so make an assumption, but make sure you write your assumption down.
=3043.731...Hz
Does the question ask for the frequency observed by the receiver, or does it ask for the frequency shift?
Added in Edit:
To further elaborate on my question:
If you use significant digits (blindly) and use 2 significant digits, then the observed frequency gets rounded to 3000Hz.
Calculating the Doppler shift from this may lead to the conclusion that the Doppler shift in frequency is 0 Hz. However, there is a way to calculate the shift without getting zero.
ΔF = Freceiver - Fsender
= Fsender((V + Vreceiver)/V) - Fsender
= Fsender( ((V + Vreceiver)/V) - 1) ,​
which can be further simplified..
  • · Replies 22 ·
