Simple circle problem involving area and circumference
34 replies · 6K views · last reply
astrololo
A stone is thrown into still water, forming ripples which travel from the center of disturbance in the form of circles. If the circumference of the circle which bounds the disturbed area is 10 ft and the circumference is increasing at the rate of 3 ft. per second, how fast is the area increasing ?
C=2πr
and
A=π∗r^2
I don't even know how to start this. I'm not supposed to use differentiation but only limiting process.[/B]
Khashishi said:
What is A as a function of C?
What is the definition of a limit?
Lim as h approaches 0 f(x+h)-f(x) divided by h
I don'T understand the other question.
This is difference quotient definition of the derivative. It's not what Khashishi asked.
Using ordinary algebra write A, the area of a circle, in terms of C, the circumference of the circle.
Why? This isn't stated in your problem description.
Because the book that I'm using doesn't want us to use differentiation. I know that I could use these formulas, but I don't want too. (It's like we didn't learn them yet)
This : rate of change of area of circle = 1/2pi * Circumference
Is this what you want ?
How did you get this?
And what we're asking in this question (restated below) has nothing to do with "rate of change" of anything.
No.
Again, using ordinary algebra, write A, the area of a circle, in terms of C, the circumference of the circle.
C=2πr
and
A=π∗r^2
In one second the circumference goes from 10 to 13 ft. You can figure out what the initial and final areas are---you have all the formulas you need. However, if all you want is a rate of increase, things simplify a lot, but I will not spoil your fun by telling you how to do it.
And what we're asking in this question (restated below) has nothing to do with "rate of change" of anything.No.
Ok, I'm going to sleep for now. I'll continue tomorrow if it doesn't bother you.
Ok, sorry for taking this long to continue this. Here : $$A=\frac{C^2}{4*\pi}$$
Yes, that's it.
For the rest of the problem, remember that ##\frac{\Delta A}{\Delta C} = \frac{A(C + \Delta C) - A(C)}{\Delta C}##, so ##\Delta A = ?##
Mark44 said:
Yes, that's it.
Ok, so I evaluated the quotient and it gave me
$$\frac{2c}{4*\pi}$$
You can't simplify that further?
Yeah sorry about that :
$$\frac{c}{2*\pi}$$
$$\frac{c}{2*\pi}$$
Is c supposed to be the circumference of the circle?
Yeah, that's what it is.
What happens if you take this equation and differentiate both sides of the equation with respect to time. What do you get? (Of course the left hand side of the equation will represent the rate of change of area with time)
I don't understand the question. I will get the rate of change of the the area depending of the time we're talking about.
Please write an equation for the time derivative of the right hand side of your equation. You do know how to take the derivative of a function, correct?
Yeah, but I am finding my derivatives with limits because it's what's asked in the problem. And it's derivative of what to time ? Area ?
Where does it say in the problem statement that you have to do it by finding the derivatives using limits? What I've been driving at is that, if ##A=\frac{C^2}{4\pi}##, then $$\frac{dA}{dt}=\frac{C}{2\pi}\frac{dC}{dt}$$
Does the mathematics make any sense to you?
It's asking me specifically to use limiting process. It's a kind of introduction to calculus problem, that's why. So I can't use the technique you showed me :/
OK. Let's do it using limits. Let A(t) = the area at time t, and let A(t+Δt) = area at time t + Δt. Also, let C(t) = circumference at time t, and let C(t+Δt) be the circumference at time t+Δt. Starting with your general equation for A in terms of C, write an equation for A(t+Δt) - A(t) in terms of C(t+Δt) and C(t).
Ok, I need to go now. I'll answer you when I get time. I'm very sorry :/
$$\frac{c}{2*\pi}$$
Then, if c is the circumference of the circle, the expression above can be simplified further still.
The problem statement implies expressing dA/dt entirely in terms of the circumference and its time derivative.
Chet
How ? I don't know what there is to do next.
What's the formula for the circumference of a circle?
