Simple Circuit Analysis - 2 Questions
The forum discussion revolves around solving two circuit analysis problems involving operational amplifiers and resistors. The first question requires designing an op-amp circuit to achieve an output of -25V, while the second question involves calculating the source voltage (Vs) in a complex resistor network. Participants discuss the application of the voltage divider rule and equivalent resistance calculations, with a consensus on the input voltage being 2V across a specific resistor configuration. The correct equivalent resistance is determined to be 2Ω, leading to further calculations for the output voltage.
  • Understanding of operational amplifier (op-amp) behavior
  • Knowledge of voltage divider rule
  • Familiarity with series and parallel resistor combinations
  • Basic circuit analysis techniques
  • Study operational amplifier circuit design principles
  • Learn advanced voltage divider applications in circuit analysis
  • Explore techniques for calculating equivalent resistance in complex circuits
  • Investigate practical applications of op-amps in signal processing
Electrical engineering students, circuit designers, and anyone involved in analyzing or designing op-amp circuits and resistor networks.
Gorz
Appologies for the amazing circuit diagrams in MS Word
For the Circuit shown below, design the opamp circuit which will give an output of -25V
For the cicruit shown, calculate Vs
Ok, for the first one, I summed the resistances in parallel and found that the the voltage 4 ohm resitor that's that would act as the voltage divider would have a value of 2 ohm, which means the volatge input using the voltage divider rule would be 2v, however the answers states that it is 0.5V
For the second question, , the 5V across the 1 ohm resistor, being in series with the other 1 ohm resistor, suggests that the sum of the voltages in that mini circuit is 10V. Resistors in parallel have the same voltage across, therefore, 10V across the 4ohm resistor. By the voltage divider rule, there should be 50V across the 16ohm resistor. Not sure how to go from here, I've tried playing around with figures for the other 2 in parallel and the 3ohm, and get nowhere near the answer of 164.48ohms
HELP!
Sunday Afternoon Bump.
Hmmm, I get 0.5V as well.
What equivalent resistance do you get when you combine all but the 18-ohm resistance? You can ignore the op-amp, since it behaves close to an open circuit as far as the resistor network is concerned.
I get an equivalent resistance of 2ohms. Working from the Resistor closest to the Op-amp.
2+2 = 4 Ohms in series, 1/4 +1/4 = 0.5 = 2ohms.
So the total resistance in the circuit is 20ohm. 20v source, therefore the input is 2v.
Where am I going wrong.
This is wrong. Find the current through 1 ohm and 4 ohm branch. That current flows through 16 ohm. I got that current 7.5 A. Now proceed.
How did you get 2 V?
First of all find the current through each branch.
I assume you are talking about the 2nd question yes?
Yes.
(1st question here)
2 Ω (and 20 Ω if you add the 18 Ω resistor) is correct.
It's 2V across the network of 4Ω & 2Ω resistors, which means 2V across the left-most 4Ω resistor. But the voltage at the op-amp input (across the right-most 2Ω resistor) will be different.
