Simple curve - not so simple function?
  • Context: Undergrad
  • Thread starter Thread starter Miffymycat
    Curve Function
The discussion revolves around identifying the function f(x) that describes a sequence of y-values corresponding to given x-values. Participants explore various mathematical models, including polynomial and hyperbolic functions, to fit the data, which exhibits a specific pattern of growth. The scope includes mathematical reasoning and exploratory analysis of sequences and functions.
  • Some participants propose that the sequence could be modeled by a second order difference equation, leading to a characteristic equation.
  • Others suggest that the sequence might be expressed as a power function or polynomial, with one participant noting that a sixth-order polynomial fit was required in Excel.
  • A participant questions whether a second order difference equation is equivalent to a second order polynomial.
  • Some participants explore the possibility of expressing the function in terms of y=f(x) and discuss various forms, including f(x) = 16 - 2^{4-x} and variations involving arbitrary constants.
  • There is speculation about whether the function could be classified as a hyperbolic function or a hyperbolic polynomial.
  • One participant notes the peculiarity of the data fitting precisely to a sixth-order polynomial, raising questions about coincidence.
Participants express multiple competing views regarding the nature of the function that fits the data. There is no consensus on whether it is best described as a polynomial, hyperbolic function, or something else entirely.
Participants acknowledge that any set of n values can fit a polynomial of order n-1, which may contribute to the observed fit of the data to a sixth-order polynomial.
Miffymycat
What is f(x) when eg
x = 0, 1, 2, 3, 4, 5, 6, etc
y = 0, 8, 12, 14, 15, 15.5, 15.75 etc (the y value at x =1 is arbitrary)
ie each successive y value adds half the difference of the preceding 2 values.
(It is effectively the inverse of a first order exponential decay where the y value halves at constant x intervals).
But it doesn’t fit an exponential ...! Could it be a type of hyperbola? or polynomial? or both? or something else entirely?
I have no decent curve fitting software and struggling to find this.
Thank you!
Try drawing it on a graph paper.
Thanks ... but how would that help, if I've already tried to fit it in Excel?
You can try finding the nth term of the sequence(That's what I do).
So you are saying that [itex]x_{n+2}= x_{n+1}+ (x_n+ x_{n+1})/2= (3/2)x_{n+1}+ (1/2)x_n[/itex]
That's a "second order difference equation" which has associated characteristic equation [itex]s^2= (3/2)s+ 1/2[/itex] or [itex]s^2- (3/2)s- 1/2= 0[/itex]. The solutions to that equation are [itex]s= \frac{3\pm \sqrt{17<br /> }}{4}[/itex]. That means that the general solution to the difference equation is [itex]8^{n/4}(C2^{\sqrt{17}n/4}+ D2^{-\sqrt{17}n/4})[/itex]
So you have a sequence defined by
[tex]x_0 = 0,~x_1 = 8,~x_{n+1} = x_n + \frac{1}{2}(x_n - x_{n-1}) = \frac{3}{2}x_n - \frac{1}{2}x_{n-1}[/tex]
Let's find a general term. We can express this sequence as follows:
[tex]\left(<br /> \begin{array}{cc}<br /> x_{n+1}\\ x_n<br /> \end{array}<br /> \right)<br /> =<br /> \left(<br /> \begin{array}{cc}<br /> \frac{3}{2} & -\frac{1}{2}\\ 1 & 0<br /> \end{array}<br /> \right)<br /> \left(<br /> \begin{array}{cc}<br /> x_{n}\\ x_{n-1}<br /> \end{array}<br /> \right)[/tex]
So, we get
[tex]\left(<br /> \begin{array}{cc}<br /> x_{n+1}\\ x_n<br /> \end{array}<br /> \right)<br /> =<br /> \left(<br /> \begin{array}{cc}<br /> \frac{3}{2} & -\frac{1}{2}\\ 1 & 0<br /> \end{array}<br /> \right)^n<br /> \left(<br /> \begin{array}{cc}<br /> x_1\\ x_0<br /> \end{array}<br /> \right)[/tex]
By using the diagonalization theory of linear algebra, we can write this as
[tex]\left(<br /> \begin{array}{cc}<br /> x_{n+1}\\ x_n<br /> \end{array}<br /> \right)<br /> =<br /> \left(<br /> \begin{array}{cc}<br /> \frac{1}{2} & 1\\ 1 & 1<br /> \end{array}<br /> \right)<br /> \left(<br /> \begin{array}{cc}<br /> \frac{1}{2^n} & 0\\ 0 & 1<br /> \end{array}<br /> \right)<br /> \left(<br /> \begin{array}{cc}<br /> -2 & 2\\ 2 & -1<br /> \end{array}<br /> \right)<br /> \left(<br /> \begin{array}{cc}<br /> x_1\\ x_0<br /> \end{array}<br /> \right)[/tex]
and thus
[tex]\left(<br /> \begin{array}{cc}<br /> x_{n+1}\\ x_n<br /> \end{array}<br /> \right)<br /> =<br /> \left(<br /> \begin{array}{cc}<br /> 2 - \frac{1}{2^n} & \frac{1}{2^n}- 1\\ 2 - \frac{1}{2^{n-1}} & \frac{1}{2^{n-1}}-1<br /> \end{array}<br /> \right)<br /> \left(<br /> \begin{array}{cc}<br /> x_1\\ x_0<br /> \end{array}<br /> \right)[/tex]
Thus we get
[tex]x_{n+1} = 2x_1 - \frac{x_1}{2^n} + \frac{x_0}{2^n} - x_0[/tex]
Since ##x_1 = 8## and ##x_0 = 0##, we get
[tex]x_{n+1} = 16 - \frac{8}{2^n}[/tex]
Thanks both! I'm not a mathematician ... just a chemist struggling to make sense of some data!
So Hallsofivy, is a "second order difference equation" the same thing as a second order polynomial? I tried to fit the data to a polynomial and it required 6th order before R2= 1 in Excel! (And not sure how you got from the series to the associated characteristic equation)
I see you guys have both written it as a series, but can it be expressed in terms of y=f(x)? And described as eg a power function or polynomial etc?
You can manipulate Micromass's approach to get, for example:
[tex]f(x) = 16 - 2^{4-x}[/tex]
And, if f(1) = a, then:
[tex]f(x) = a(2 - 2^{1-x}) = 2a(1 - \frac{1}{2^x})[/tex]
... building on micromass's reply ... something like y = 2a -(a/2^x)? where a is an arbitrary constant. Is it a hyperbolic function??! Or a hyperbolic polynomial! does that exist?
Thanks Perok ... I was sending mine while yours was arriving - I was close! So does the function fit one of those categories?
I would say it's just a variation of a power function (powers of 1/2).
OK - a bit weird though, that it fits precisely to polynomial order 6! Coincidence?
Any set of n values will fit a polynomial of order n-1.
