How Does Adding Particles Affect Entropy in a Multi-Level Energy System?
  • Thread starter Thread starter HalfManHalfAmazing
The discussion focuses on calculating the entropy of a system with two distinguishable particles distributed across three energy levels, totaling 2e. The initial calculation suggests there are four microstates for this configuration, leading to a specific entropy value. When a third distinguishable particle with zero energy is added, the number of combinations increases, but there is confusion regarding the correct multiplicity and resulting entropy increase factor, with one participant calculating a factor of 1.29 instead of the expected 1.63. The conversation also touches on the implications of using indistinguishable particles, prompting further exploration of general expressions for entropy in multi-particle systems. The thread highlights the complexities of entropy calculations in statistical mechanics.
HalfManHalfAmazing
Two distinguishable particles are to be distributed between 3 energy levels: 0, 1e and 2e such that the total energy level E = 2e.
a) What is the entropy of the system?
b) if a third distinguishable particle with zero energy were added to the system show that the entropy increases by a factor of 1.63.
c) Reevaulate a) with undistinguishable particles. does b) still hold if this time the added particle is undistinguistable?
S = k\ln\Omega
Various methods of determining multiplicity...
Okay. First up this system has 3 possible states per particle and we've got 2 particles. We want the multiplicity of the macrostate 2e. Thus we need to determine the number of microstates that this macrostate has. Looks to me like we have the following states: 0/2, 2/0, 1/1, 1/1. Thus 4 microstates? so we plug 4 into the omega from the entropy formula and we're done?
Next, adding the third 0 energy level particle confuses me. It won't change the number of combinations required to reach 2e, will it? or do we do something like this: 0/2/0 0/0/2 2/0/0 0/1/1, 1/1/0, 1/0/1? Also, what formula could i use to make this a general expression such as what is the entropy of n particles in n states? I know it involves factorials...
Thanks!
anyone tried 'er out?
You're right on both counts. Adding the 3rd particle changes the number of combinations in just the way you surmised.
As for n particles in n states, I'll leave that for someone else. :biggrin:
I find a multiplicity of 6 for b. in which case the when i check the factor of increase i only find a factor of 1.29, not 1.63. So that can't be right?
  • · Replies 22 ·
  • · Replies 22 ·
