Simple Harmonic Motion: Finding Frequency and Potential Energy Function
The problem involves a particle of mass m subjected to a force described by Fx=-Fosinh(αx), where α and Fo are constants. The objective is to find the frequency of small oscillations around the equilibrium position and to derive the potential energy function.
  • The original poster attempts to solve the problem using a guessed solution for the position as a function of time, but expresses uncertainty about the correctness of this approach. They seek clarification on how to find the frequency.
  • Some participants suggest performing a series expansion of the force function to understand its behavior for small displacements, leading to a comparison with the force of a spring.
  • Questions arise regarding the relationship between the force function and the spring constant, as well as how to solve the resulting differential equation for simple harmonic motion.
The discussion is ongoing, with participants exploring different interpretations of the force function and its implications for small oscillations. Some guidance has been provided regarding the standard form of the differential equation for simple harmonic motion, but there is no explicit consensus on the approach to take.
Participants are navigating the complexities of hyperbolic functions in the context of simple harmonic motion, which may be leading to confusion about the expected forms and solutions. There is an emphasis on understanding the linearity of the force function for small displacements.
briteliner
a particle of mass m moves in one dimension with an applied force Fx=-Fosinh(\alphax) where \alpha and Fo are constants. find the frequency of small oscillations about the equilibrium position. next, find the potential energy function and sketch it.
Guess: x(t)=Asinh(wt)
dx/dt=Awcosh(wt)
d2x/dt2=Aw2sinh(wt)
mAw2sinh(wt)=-Fosinh(\alphax)
w=\alpha
Fo=-Aw2m
A=-Fo/mw2
I have a feeling this is not the right way to go about this...Is it correct? If not, why? and how do i go about finding the frequency?
For SHM, how must the force depend on displacement from equilibrium? Hint: Do a series expansion of F(x) to see how it behaves for small x.
ok so after the series expansion F(x)=-F(\alphax)+((\alphax)3)/3!+...)
the force depends on the displacement directly. but how does this help me get the frequency?
Compare that force function to that of a spring for small x. (Assuming you know how to find the frequency of an oscillating spring. If not, look it up.)
the force for a spring is just F=-kx. so does F\alpha =k?
Yes. k = F0α
ok, but to get the frequency i need to solve the differential equation that i attempted above. how do i go about that?
The differential equation you need to solve is just the standard one for SHM:
m d2x/dt2 = -kx
The key point here, that I'm afraid you've missed, is that for sufficiently small values of x, the function is linear in x
From here, you can say that the force is of the form:
F(x)=-(\alpha F_0)\cdot x
I think you've fallen into the pit-fall of this question. You're used to SHM being described by the regular trigonometric functions, sin(x), cos(x), but here you were confronted with the hyperbolic sine function and were thrown off.
Before we try and guess the solution to the differential equation, let's first find it.
Looking at NSL for this mass, we can find the following differential equation:
ma=-(\alpha F_0)\cdot x
m\ddot x=-(\alpha F_0)\cdot x
\ddot x=-(\frac{\alpha F_0}{m})\cdot x
Solving this differential equation is fairly simple. Just like the equation 5=10-x asks "which number, when subtracted from 10 gives 5?"
This differential equation asks, "which function, when differentiated twice with respect to time, gives itself times a negative constant?"
\omega^2\equiv \frac{\alpha F_0}{m}
The differential equation then turns to:
\ddot x=-\omega^2 x
Now we'll guess!
x(t)=?
But how do we know this is really a solution? How do we know if we guessed right?
Just like how you would double-check your answer for 5=10-x by plugging in x=5 and seeing that you get a true statement, we'll do the same here.
Differentiating our solution once with respect to time gives us:
\frac{dx(t)}{dt}=?=\dot x(t)
Differentiating once more:
\frac{d\dot x(t)}{dt}=?=\ddot x(t)
And then look to see if it checks out or not.
Once you have x(t), you can easily find its period. Before you get caught up in the math, remember that you don't care about the amplitude or phase shift of the periodic function, but only about its period.
