Simple Harmonic Motion (Mass on a Spring)
3 replies · 9K views · last reply
seichan
[SOLVED] Simple Harmonic Motion (Mass on a Spring)
A solid cylinder of mass M= 10.8 kg is attached to a horizontal massless spring so that it can roll without slipping along a horizontal surface, as shown in the Figure. The force constant of the spring is k= 346 N/m. The system is released from rest at a position in which the spring is stretched by a distance x= 17.0 cm. What is the translational kinetic energy of the cylinder when it passes through the equilibrium position? What about the rotational KE?
http://i3.photobucket.com/albums/y65/amenochikara/prob02a.gif
Translational Energy-.5mv^2
Rotational Energy- .5Iw^2
Angular Velocity (spring)- sqrt(k/m)
Alright... I only have this problem left and it's frustrating me. For the first part, I used translational Energy for a spring (.5kx^2), but I am not taking the mass into account. All the example problems we were given have amplitudes and other useful things to use to compute velocity. So, I moved onto what I thought would be the easier one, rotational. For this, I tried using .5(r^2)(k) when I realized, much to my dismay, that I had no radius for the cylinder. Any alternative ways I am not thinking of? Thanks so much.
You actually don't need radius of cylinder. At the beginning you have just energy of spring
0.5kx^2 , that equals sum of rotational and translational energy in equilibrium position. The you should know that
[tex]\omega =v/r ~,~E_t=0.5mv^2~,~E_r=0.5I~\omega^2[/tex]
Now since I for cylinder is 0.5mr^2 , r falls out. You have only equation for v then.
Can someone please explain to me where the formulas are coming from for translational energy, etc?
