SIMPLE:how do you solve (sin x)/x = 0.99
  • Thread starter Thread starter LM741
The equation (sin x)/x = 0.99 has a numerical solution of approximately 0.2459674 when solved using methods such as Newton's Method and fixed-point iteration. The discussion highlights that there is no closed-form solution, and the approximation involves using the Taylor series expansion for sine. The quadratic equation derived from the approximation is a^2 - 20a + 1.2 = 0, where a = x^2, leading to the valid solution of 0.2459674 and an extraneous solution of 4.465366.
  • Understanding of Taylor series expansions, specifically for sine functions.
  • Familiarity with numerical methods, particularly Newton's Method and fixed-point iteration.
  • Basic knowledge of solving quadratic equations.
  • Proficiency in working with radians in trigonometric functions.
  • Research Newton's Method for root finding in numerical analysis.
  • Learn about fixed-point iteration techniques and their applications.
  • Study the Taylor series expansion for trigonometric functions in detail.
  • Explore solving quadratic equations and their implications in real-world problems.
Mathematicians, engineering students, and anyone involved in numerical analysis or solving trigonometric equations will benefit from this discussion.
LM741
the answer is 0.24 (working in radians)
how to you get this
thanks!
There is no closed form solution. You might research something like a Newton's Method root finder. I did a quick fixed point interation and arrived at 0.24532 but it took over a 100 iterations to reach it.
I started with a guess of .5 and iterated
x = \frac { \sin x } {.99}
I did an approximation by hand,
Take the first terms of taylor series for sine
sin(x) = x - \frac { x^3 } {6} + \frac {x^5} {120}
\frac { \sin x } {x} = 1 - \frac { x^2 } {6} + \frac {x^4} {120} = 0.99
x^4 - 20x^2 + 1.2 = 0
Substitute, a = x^2
a^2 - 20a + 1.2 = 0It's an easy quadratic equation, also got 0.2459674, and other solution 4.465366 which doesn't work.
Thread moved to math homework forum.
willyf1 said:
I looked for docs that referring to this problem but couldn't find any of those, do you have a clue?
What about what's solution?
