Momentum Change in a Collision with Combined Units
  • Context: Undergrad
  • Thread starter Thread starter sameeralord
    Momentum
The discussion centers on the calculation of momentum change in a collision involving two objects with initial momenta of 100 kg m/s and 120 kg m/s, resulting in a combined momentum of 20 kg m/s post-collision. The key issue identified is the inability to determine the individual changes in momentum without knowing the masses of the two objects involved. The total momentum is conserved at 20 kg m/s to the left, but the lack of mass data prevents the calculation of individual momentum changes.
  • Understanding of momentum conservation principles
  • Familiarity with basic physics concepts of mass and velocity
  • Knowledge of momentum calculation formulas
  • Ability to analyze collision scenarios in physics
  • Study the principles of momentum conservation in elastic and inelastic collisions
  • Learn how to calculate individual momentum changes using mass and velocity data
  • Explore examples of combined mass systems in collision physics
  • Investigate the effects of varying mass ratios on momentum outcomes
Physics students, educators, and anyone interested in understanding collision dynamics and momentum conservation principles.
sameeralord
In this collision
Before= p=100 kg m/s---> <-----p=120 kg m/s
After= <--combined unit P= 20 kg m/s
In this question when I work out the change in momentum for 2 objects it is not the same. When there is a combined unit traveling after the collision can't you find the change in momentum?
What's the problem? The total momentum is 20 kg-m/s to the left both before and after the collision.
How do you find the change in momentum of each object? Is the data insufficient?
I see your question. Unless you know the masses of the two objects, you don't know how much of the final momentum belongs to each object, so you can't calculate the individual changes.
  • · Replies 53 ·
  • · Replies 35 ·
  • · Replies 21 ·
18K
