Simple Pendulum motion - Numerical Integration
12 replies · 4K views
Alexanddros81
The differential equation of motion for the simple pendulum can be shown to be
##\ddot {θ} = -(g/L)sinθ##. Given that L=9.81 m and that the pendulum is released
from rest at θ=60deg, determine the time required for the pendulum to reach the position
θ=0deg. Use Δt=0.10s, and compare your answer with the analytical solution of 1.686s
I guess I am missing something...
I need to compute θ value? How do I do that? Do I find θ by using x, L, s ?
Since ##u_{\theta} = \dot \theta##, ##\dot u_{\theta} = \ddot \theta##.
So, you are solving the equation ##\ddot \theta = -\sin{\theta}##. No need to introduce x or s.
Hi.
Can you check the following if it is correct?
By reading on a Dover book regarding differential equations and browsing on the web
i give the following as a linear solution for the undamped pendulum problem for small angle θ.
Do I proceed with the linear equation of the pendulum equation or with non-linear for this
particular problem? (Initial condition for θ = 60deg)
Also I want to use the 4th order Runge-Kutta method.
With an initial condition of θ=60 degrees, θ in radians is 1.05, and sin(θ) = 0.866, so you can see that the small angle approximation fails badly. You need to use the full non-linear equation in your Runge-Kutta code. That is the whole point of the exercise. With the small angle approximation, the equation can be solved analytically and there is no need for numeric integration.
So the equivalent first-order diff.equations are
##u_θ=\dot {θ}## and ##\dot {u_θ} = -(g/L)sinθ##
Correct?
Correct?
Correct.
How do I implement the above runge-kutta 4th order to this specific problem?
I don't know how...
Is ##k1=f(θ_i)## ? and ## k2=f(θ_i + 1/2h) ## etc. ?
Is ##\dot {u} = f(θ)## ? (not according to the above)
Is ##k1=f(θ_ι, ω_i)## etc ?
Since this is a second order problem, your yi's and k's are two component vectors, with the components being [itex]y_i = (\theta, \dot \theta)[/itex]. Here your function [itex]f(t, y_i) = f(t, (\theta, \dot \theta)) = (\dot \theta, -\frac{g}{L} \sin(\theta))[/itex]. Note that f is independent of t, which simplifies things. So you start with [itex]y_0 = (\theta, \dot \theta) = (\theta_0, 0)[/itex]. So then [itex]k_1 = f(0,(\theta_0,0)) = (0, -\frac{g}{L} \sin(\theta_0))[/itex] , [itex]k_2 = f(h/2,y_0 + h/2*k_1) = f(h/2,(\theta_0,-\frac{g}{L} \sin(\theta_0)*h/2))=(-\frac{g}{L} \sin(\theta_0)*h/2, -\frac{g}{L} \sin(\theta_0))[/itex] and so on. Does this help?
to phyzguy:
thanks this is the information I needed. Is there some more info related to this?
A few questions:
1) since ##y_0 = (\theta, \dot \theta) = (\theta_0, 0)## we say that ##k_1 = f(0,(\theta_0,0)) = (0, -\frac{g}{L} \sin(\theta_0))##
the last expression for k1 is ##f(0,(\theta_0,0)) = (0, -\frac{g}{L} \sin(\theta_0))##
The above means that t=0 (first parameter) and ##y_0 = (\theta_0,0) = -\frac{g}{L} \sin(\theta_0)## (second parameter). Correct?
2) Is your expression for k2 correct? If yes how did you derived it?
I think you're still not getting it. The function f returns the derivative of y, so since [itex]y = (\theta, \dot \theta)[/itex], [itex]f(y) = (\dot \theta,-\frac{g}{L} \sin(\theta))[/itex]. From there you just plug in. To find k2 you just plug in [itex]y_0 + \frac{h}{2} k1[/itex] into f. You wrote:
The first equality is correct, but the second is not.
Here is a link which explains in more detail. Are you writing some computer code to do this? If so in what language? You might try defining the code, maybe that will help. Define a function f that takes y as its input, and define another function that does one RK4 step.
