How can I solve a quadratic equation with a simple homework statement?
The forum discussion centers on solving the quadratic equation -2kx² + 4x + 6k = 0 using both the quadratic formula and the method of completing the square. The quadratic formula yields the solutions x = [1 ± sqrt(1 + 3k²)] / k, while the completing the square method requires dividing by -2k and manipulating the equation to find a perfect square. Participants emphasize the importance of proper notation and parentheses in mathematical expressions to avoid confusion. The discussion also highlights common mistakes in algebraic manipulation and the significance of understanding the derivation of the quadratic formula.
  • Understanding of quadratic equations and their standard form
  • Familiarity with the quadratic formula
  • Knowledge of completing the square method
  • Basic algebraic manipulation skills
  • Study the derivation of the quadratic formula from completing the square
  • Practice solving quadratic equations using both the quadratic formula and completing the square
  • Explore the discriminant and its role in determining the nature of the roots
  • Watch instructional videos on solving quadratic equations for visual understanding
Students learning algebra, educators teaching quadratic equations, and anyone seeking to strengthen their mathematical problem-solving skills.
autodidude
Find the exact (surd) answer
-2kx^2 + 4x +6k = 0
Attempt 1 (quadratic formula method)
-2kx^2 + 4x +6k = 0
-> -(-2) +- sqrt((-2)^2 - (4 x k x -3k)0 / 2k
-> 2 +- sqrt(4+12k^2) / 2k
-> 2 +- sqrt(4(1+3k^2) / 2k
-> 2 +- sqrt(4) sqrt(1+3k^2) / 2k
-> 2 +- 2sqrt(1+3k^2) / 2k
-> x = sqrt(1 + 3k^2) / k
Given solutions are:
x = sqrt(3k^2 + 1 + 1) / k
and
x = -sqrt(3k^2 + 1 - 1) / k
Attempt 2 (completing the square method)
-2kx^2 + 4x + 6k = 0
-> kx^2 - 2x - 3k = 0
-> kx^2 - 2x + 1 -1 - 3k = 0
-> kx^2 - 2x + 1 = 1 + 3k
Not sure how to factor kx^2 - 2x + 1 but if I move k to the RHS, wouldn't the k's cancel out? I'm interested in solving it both ways as I'm trying to teach myself this and I don't want any holes in my knowledge
Thanks a lot
-2kx^2 + 4x +6k = 0
Do some simplification first by dividing both sides by -2, to get
kx^2 - 2k - 3k = 0
-2kx^2 + 4x +6k = 0
Not sure what you're doing above. Make sure you use enough parentheses. The final 2k is under everything.
Should be
x = [2 +/- sqrt(4 + 12k^2)]/(2k)
Each step here should be an equation, or at least indicate that each expression is equal to the one above.
No, the numerator should still have two terms.
x = [1 +/- sqrt(1 + 3k^2)]/k
and
Neither of the above is correct. Are you sure you're writing them correctly?
Thanks a lot
Sorry but I don't understand where the 1 comes from...if I cancel the twos, shouldn't I just be left with x = [+/- sqrt(1 + 3k^2)]/k
Yeah the second given solution is definitely written out like that, or maybe like this
x = [sqrt(3k^2 + 1 + 1)] / k
and
x = [-sqrt(3k^2 + 1 - 1)] / k
Find the value of k by using the discriminant \Delta = b^2 - 4ac.
This is a very common mistake.
This is something like saying that
\frac{2 + 6}{2} = 6
I hope you recognize that the actual answer is 4.
The only time you can cancel is when the numerator and denominator are factored, which is not the case in my example or in your problem.
x = \frac{2 \pm 2\sqrt{1 + 3k^2}}{2k} = \frac{2(1 \pm \sqrt{1 + 3k^2})}{2k}
Now 2 is a factor in both numerator and denominator, so now we can cancel.
x = \frac{1 \pm \sqrt{1 + 3k^2}}{k}
and
I have no idea where they got these. Both look like they have typos. Why would anyone write 1 + 1 and 1 - 1 in a final answer?
^ Ah it makes sense now...cheers!
It is not possible to find the value of k in this problem.
and
The brackets are written incorrectly. Instead of writing:
It should be:
x = [sqrt(3k^2+1) + 1] /k
x = {-[sqrt(3k^2+1) - 1]} /k
which is truly confusing, I have no clue why they would decide to put the 1 after the square root sign.
It's really just another way to write:
x = [1 +/- sqrt(3k^2+1)] / k
It's confusing with all those brackets, but what I did is analogous to the following:
a - b = -(b - a)
For example, with 5 representing what's before the +/- sign (for the negative case only) and 4 representing what's under the square root sign:
5 - 4 = -(4 - 5)
1 = -4 + 5
1 = 1
-(b+a) doesn't work:
= -(5 + 4)
= -5 - 4
= -9
At least that's my reasoning via the distributive property.
a - b = -(b - a)
OK, I see what you did. I didn't notice that you had inserted another pair of brackets.
5 - 4 = -(4 - 5)
1 = -4 + 5
1 = 1
= -(5 + 4)
= -5 - 4
= -9
Yeah, that must be it :p
How would you solve it by completing the square?
When you have an equation of the form ax^2+ bx+ c= 0 with a\ne 1, the simplest way to use "completing the square" is to first divide through by a.
You have -2kx^2 + 4x +6k = 0 so divide through by -2k:
x^2- \frac{2}{k}x- 3= 0
and then write it as
x^2- \frac{2}{k}x= 3
Now compare that to (x- a)^2= x^2- 2ax+ a^2. with
-\frac{2}{k}x= -2ax
what is a? What do you need to add to both sides to get a "perfect square" on the left?
I just though I would mention something you might want to try. If you take ax^2+ bx+ c= 0 and factor it the way that HallsofIvy says, you'll actually end up with the quadratic formula.
Just in case you wanted to see where the quadratic formula comes from.
Edit: This video might help you understand the process if you get stuck.
https://www.youtube.com/watch?v=mDmRYfma9C0
-\frac{2}{k}x= -2ax
Don't you have to add and subtract (b/2)^2 as well. So -2x/k is the same thing as -(2/k)x?
Sorry there are lot of holes in my math knowledge.
@ebits21: thanks I'll check it out
  • · Replies 27 ·
  • · Replies 22 ·
