Simple question regarding weight flow rate and specific gravity
The discussion revolves around the application of specific gravity in a hydraulics problem, particularly its multiplication with the unit weight of water (9810 N/m³) to determine weight flow rate. Participants explore the reasoning behind this relationship and its implications in various contexts.
  • Participants question the necessity of multiplying specific gravity by the unit weight and seek clarification on its absence in the formula. Some express confusion about the use of weight per unit time as a measure of flow rate and discuss the implications of varying gravitational contexts.
The conversation is ongoing, with participants sharing insights about specific gravity and its relationship to unit weight. There is a recognition of the unusual nature of the problem's requirements, and some participants suggest that the problem's framing may detract from the underlying physical principles.
Participants note that the problem does not specify certain conditions, such as pressure and temperature, which could affect density. There is also mention of the potential confusion arising from the use of unconventional units in the problem statement.
drdyke
A 100 mm diameter plunger is being pushed at 60 mm/sec into a tank filled with oil having sp.gr. of 0.82. If the fluid is incompressible, how many N/s of oil is being forced out a 30-mm diameter hole?
weight flow rate = unit weight x Q
Q1 = Q2
i’m studying my textbook in hydraulics and i’d like to know the reason why specific gravity is used in one of the problems. it’s a pretty simple problem and i understood it mostly except why specific gravity is multiplied to 9810 (the unit weight of water). if the SG is given in the problem, is it always multiplied to the unit weight?
Thanks
Have you looked up what "specific gravity" means?
Ideally you would do that in the textbook, but failing that google will probably have the answer.
i do know that specific gravity is the ratio of density of fluid over density of water. what i am confused tho is why it is multiplied to the unit weight 9810 when it isn’t stated in the formula? i just want that part cleared up so i won’t be confused on future problems anymore
thanks
What formula?
(I have to say, Newtons is a peculiar way to express a quantity of oil being exuded. Far more reasonable to express it as a mass.)
thanks
Ideally your textbook should tell you what value to use if the question does not explicitly state a value. Remember that density depends on pressure and temperature, neither of which are given in the question.
haruspex said:
What formula?
here the process became
weight flow rate = unit weight (SG) x Q
You are expected to be able to adapt a formula if necessary. Don’t expect a different formula for every possible slightly different variation of a problem.
The question asks for the flow-rate in N/s, so you know that you are being asked to calculate the weight of oil coming out per second. (As already noted, this is a rather unusual way to express flow-rate.)
You should be given the nominal value for the density of water (1000kg/m³) and for the acceleration due to gravity (9.81m/s² = 9.81 N/kg). You are expected to sort out for yourself that:
a) the density of water can be expressed as 1000*9.81 = 9810 N/m³
b) the density of oil can be expressed as 9810 x 0.82 N/m³
c) multiplying ##Q_2## (outgoing flow rate in m³/s) by 9810 x 0.82 N/m³ will give you the flow- rate in N/s as required.
Also, note that the model answer has some faults with rounding and use of significant figures. You may want to see if you can spot the faults!
… where Q is the volume per unit time, and unit weight means weight per unit volume.
(volume/time)x(weight/volume)=(weight/time).
drdyke said:
…here the process became weight flow rate = unit weight (SG) x Q
SG is defined as the mass of a given volume of the substance divided by the mass of an equal volume of water.
weight of volume V of substance = (mass of volume V of substance) x g
= (mass of volume V of water) x SG x g = (weight of volume V of water) x SG
Dividing through by the volume:
weight per unit volume V of substance = (weight per unit volume V of water) x SG
i.e.
unit weight of substance = (unit weight of water) x SG
What if this oil tank happens to be located on the ISS, on the moon or in the engine compartment of a formula 1 race car in the middle of turn 1 using a convention that ##g## is measured relative to the race car frame.
Agreed, but this bizarre use of weight per unit time as a measure of flow rate seems to come from the problem setter. We can but sigh.
I have occasionally encountered questions of this kind where the author expects an answer in outré units apparently for no other reason than to be irritating. The end result is detraction from the underlying physical principle that is showcased. Sigh indeed.
Judging from 8.18 at , it may have arisen as a translation from pounds/s.
  • · Replies 22 ·
10K
  • · Replies 29 ·
16K
12K
  • · Replies 21 ·
9K
