Simple thought experiment with Stefan-Boltzmann law: energy
  • Context: Undergrad
  • Thread starter Thread starter haushofer
The discussion revolves around a thought experiment involving the Stefan-Boltzmann law and the interaction of two spheres acting as black bodies at different temperatures. Participants explore the implications of their radiation exchange and the resulting temperatures, raising questions about energy conservation and equilibrium states.
  • One participant presents a calculation involving two spheres, one at 500 K and the other at 600 K, and questions the resulting temperatures after they interact.
  • Concerns are raised about the equation used to describe the power emitted by each sphere, specifically whether the term representing absorbed power should be positive or negative.
  • Another participant agrees that the sign of the absorption term is crucial and suggests that the total power should be less than the sum of the individual powers due to mutual absorption.
  • There is a discussion about whether the additional energy absorbed by the colder sphere from the warmer sphere leads to a "runaway effect" or violates energy conservation.
  • One participant proposes an alternative formulation of the equations to clarify the equilibrium states without the accents on the right-hand sides.
  • Another participant expresses confusion about how the hotter sphere could cool down by absorbing radiation from the colder sphere.
  • A later reply indicates that the initial confusion has been resolved, but does not elaborate on the resolution.
Participants express differing views on the correct formulation of the equations governing the power exchange between the spheres, particularly regarding the signs of terms related to absorption and emission. The discussion remains unresolved regarding the implications for energy conservation and the behavior of the spheres at equilibrium.
Participants note that the interaction between the spheres may lead to complexities in energy conservation that are not fully addressed in their calculations. The dependence on assumptions about the nature of radiation exchange and the definitions of terms used in the equations is acknowledged.
haushofer
Insights Author
TL;DR
Thought experiment where 2 spheres influence each other's temperatures.
Dear all,
in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows.
I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate the total power emitted, ##P = A \sigma T^4 = 4 \pi r^2 \sigma T^4## with ##\sigma = 5.670374419 \times 10^{-8} W m^{-2} K^{-4}##. Now we place a second sphere (2) with also radius ##r## (for simplicity) at a distance R from sphere 1, with a temperature of exactly ##T_2 = 600 K##. The question is: what happens with both temperatures, in light of the fact they both absorb a small portion of each others radiation?
Let's put some numbers in. I take ##r = 1 \ m## and ##R = 10 \ m## (we want ##r<<R## to simplify the calculations, so this is just on the edge, but it should work). Drawing the picture, one concludes that the emitted power of sphere 1 is spread over a spherical surface ##4 \pi R^2##, and the surface of sphere 2 which absorbs equals ##\pi r^2##. So the fraction ##c## of power absorbed is given by
$$ c \equiv \frac{\pi r^2}{4 \pi R^2} = \frac{r^2}{4 R^2} = 0.0025$$
The power emitted is given by ##P = A \sigma T^4##. Now some energy considerations: The power emitted after we place the two spheres at a distance ##R## apart in a vacuum becomes altered, which I indicate with an apostrophe. For the new equilibrium states of the emitted powers we then obtain
$$P_1'=P_1+c \cdot P_2' \ \ \ , \ \ \ P_2'=P_2+c \cdot P_1'$$
I.e. the power emitted in the new situation is just the power emitted because of the own inner heatings, plus the fraction of power absorbed from the other sphere, which in equilibrium will be emitted again. Solving this gives
$$P_1'=\frac{P_1 + c \cdot P_2}{1-c^2}$$
which can be plugged in to solve for ##P_2'##.
If I now plug in the numbers, I can calculate ##P_1'## and ##P_2'## and hence ##T_1'## and ##T_2 '##, to find ##T_1'=500.65 K## and ##T_2'=600.18 K##. So the initially warmer sphere is also 'heated' (i.e. it absorbs electromagnetic radiation, raising its temperature) by the colder sphere. The total power emitted changes by
$$P_1'+P_2' = \frac{P_1 +P_2}{1-c} = 1.0025... (P_1 + P_2)$$
My questions:
1) Does this calculation (and approximation) make sense? Are these two new temperatures the new equilibrium states of both spheres?
2) Somehow I'm a bit uneasy with energy conservation. Where did the extra 0.25% of energy come from? Doesn't this cause some "runaway effect"?
I have a feeling something goes wrong. Many thanks. :)
Science news on Phys.org
I don't understand this equation ##P_1'=P_1+c \cdot P_2'##. Is ##c## positive or negative? It seems to me that the total power loss by sphere 1 in the vicinity of sphere 2 should be less than its power loss when it sits by itself for the reason you mentioned
Absorption is the opposite of emission so on the left hand side if ##P_1## is emitted power, the second term should have a negative sign in front with the understanding that ##c## is positive.
If you reverse the sign of ##c## in your equations, the total power becomes $$P_1'+P_2' = \frac{P_1 +P_2}{1+c} <(P_1+P_2)$$ which makes eminent sense. The whole is less that the sum of the parts as the spheres absorb a fraction of each other's energy.
Positive; it's a ratio of surfaces. But I agree this is the tricky equation. I reasoned that sphere 1 receives (hence the + sign) an additional radiation power of ##c \cdot P_2'## from sphere 2, which eventually after reaching equilibrium again has to be reemited. So it's temperature rises becauses of the extra power absorbed from sphere 2. And vice versa for sphere 2.
Maybe I should write
$$P_1'=P_1+c \cdot P_2 \ \ \ , \ \ \ P_2'=P_2+c \cdot P_1$$
to find the new equilibrium, so without the accents on the right hand sides. I'll look at it more closely tomorrow, but clearly I'm misunderstanding something fundamental here.
@kuruman I only see now your comment about absorption, emission and minus signs. But isn't the whole point that if (say) sphere 1 absorbs power from sphere 2, eventually this extra energy is reemitted? That's why I choose a plus sign for c.
It looks to me that each sphere is radiating into a sky which is slightly obstructed. So the combined radiation measured at a great distance will initially be less than the sum of the two free space powers. But when the two objects reach equilibrium the power measured at a great distance will be the sum of the two.
I guess my confusion is this: why would the hotter sphere cool down a bit by absorbing radiation from the colder sphere?
  • · Replies 101 ·
9K
