Simple Uniform Acceleration Question
The discussion revolves around a physics problem involving uniform acceleration of a spaceship, transitioning from 65.0 m/s to 162.0 m/s over 10 seconds. Participants clarify that uniform acceleration and constant acceleration are equivalent, emphasizing the need to calculate acceleration using the change in velocity over time. The correct formula for distance, d = 1/2(Vf + Vi) * t, is highlighted, and one user successfully calculates the distance as 1135 m, noting a slight discrepancy with the book's answer of 1140 m. The conversation underscores the importance of understanding the underlying principles of physics rather than just applying formulas.
wwwwww
Hello new user here. I'm utterly confused about uniform acceleration as my book does a very poor job (in my opinion) of explaining it. Could somebody please help me with this problem?
A spaceship far from any star or planet experiences uniform acceleration from 65.0m/s to 162.0m/s in 10.0s. How far does it move?
Vf=Vi+at
d=Vit+.5at
Well I tried to use the equation d=(Vf+Vi)/2 but I checked my answer with my teacher's answers and the answers were way different. I think it's because the problem uses uniform acceleration and not constant acceleration.
Vf=Vi+at
d=Vit+.5at
why not use the formula
d = 1/2(Vf+Vi).t
You seem to have forgotten there is a time factor in the formula.
Of course you could easily use the first two you quoted. Use the first to find the acceleration, then the second to use that acceleration to find the distance.
Final point: Uniform acceleration and Constant acceleration are the same thing.
Uniform acceleration and constant acceleration are the same thing, it means that the acceleration remains at a fixed value throughout the course of motion.
The problem is giving you two velocities, since it is stated that the acceleration is constant, you must compute the acceleration from the two velocities.
So you need to ask yourself, what is acceleration? It is the change in velocity over a period of time. This should give you everything you need to answer the question. :]
EDIT: In physics, you shouldn't just try to throw a formula at things, but rather reason it through and make sense of the formulas.
d = 1/2(Vf+Vi).t
The formula that PeterO threw at this problem is simply another way to write
displacement = (average velocity) ✕ time .​
In the case of uniform acceleration, it's true that
(average velocity) = 1/2(Vf + Vi).​
Oh thanks for the help. I got 1135 m, and the answer in the book is 1140 which I guess is close enough.
Correct.
(Looks like they rounded off to 3 significant figures.)
Your answer is correct. If that is the answer printed in the book it is wrong.
If they were trying to express to 3 significant figures it should have been 1.14 x 103 m or perhaps 1.14 km
I didn't just throw in that equation.
There are 5 equations covering uniformly accelerated motion. wwwwww had listed 2 of them, I brought in a 3rd, more directly applicable, one and there are 2 more to go, but neither of them has direct application to this question.
Besides when wwwwww had listed d = (Vf + Vi)/2 it looked like a mis-quoting of the equation of motion I referred to.
17K
