Solving a Vector Problem: v1 and v2 Sum to <-4,1,1> with Given Conditions
  • Thread starter Thread starter Loppyfoot
    Vector
To solve for vectors v1 and v2 that sum to <-4, 1, 1>, v1 must be a multiple of <2, 5, -4>, while v2 must be perpendicular to it. The equation v1 = K<2, 5, -4> can be established, leading to v2 being expressed as <-4, 1, 1> - K<2, 5, -4>. To find the scalar K, the coordinates of v2 can be determined first, utilizing the condition that v2 is perpendicular to <2, 5, -4>. The discussion emphasizes the importance of understanding vector relationships rather than relying on the cross product.
Loppyfoot
Find two vectors, v1, and v2, whose sum is <-4,1,1>, where v1 is parallel to <2,5,-4>, and where v2 is perpendicular to <2,5,-4>
I am guessing I use the cross product for this equation, but I'm confused about how to start this problem.
any hlep at all would be greatly appreciated!
Don't use the cross product.
Write v1 and v2 using coordinates. You're given that they add to <-4, 1, 1>. You're also given that v1 is parallel to <2, 5, -4>, which means that v1 is some constant multiple of <2, 5, -4>. You're also given that v2 is perpendicular to <2, 5, -4>. Two vectors being perpendicular should suggest a particular operation.
So, first I realized that v1= K<2,5,-4>
Then I figured that since v1+v2=sum, ;
then:
<4,1,1> - K<2,5,-4> = v2
Now, what process would I use to find K?
Then what are the coordinates of v1?
then:
How about finding coordinates for v2 first?
Also what can you do with the given information that v2 is perpendicular to <2, 5, -4>?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
11K
  • · Replies 79 ·
