Simplifying (A + C)(CAB + CAB')'
10 replies · 3K views · last reply
Jaehyun
(A OR C) AND NOT(C AND A AND B OR C AND A AND NOT B)
or
(A + C) (CAB + CAB')'
(A+B)' = A'B'
A(B+C) = (AB) + (AC)
(AB)' = A' + B'
The attempt at a solution
I'm not sure how I'm suppose to expand (CAB + CAB')' for simplifying. I keep arriving at false which shouldn't be the case.
(A + C) (CA)' (B + B')' (I'm not sure if this is what your suppose to do)
or
(A + C) (C'A'B'C'A'B) (Not sure if i used (A+B)' = A'B' correctly)
Thanks - Jay
Hello Jaehyun, :welcome:
Pity you deleted part of the template: relevant equations are needed to do what you want. List a few and you'll see which you need
I'm confused on how this rule: (A+B)' = A'B' is used to help with (CAB + CAB')'.
I was searching for (xyp + xyq) = xy (p+q)
I don't think this rule would work as it leads to a false (CA)' (B + B')' = (CA)' (1)' = 0 unless this does not work for NOT.
By the way, (XY)' ≠ X'Y' !
(A + C) (C' + A') (B + B')'
(AC' + AA' + CC' + CA') (B + B')'
(AC' + CA') (B + B')'
So then (B + B')' = 0 meaning there is no simplified expression?
My "I was searching for (xyp + xyq) = xy (p+q)" : was meant to lure you into (CAB + CAB') = CA(B+B') = CA
(A + C) (CAB + CAB')' does NOT lead to (A + C) (CA)' (B + B')' !
But (CAB + CAB') = CA(B+B') = CA is missing the NOT portion (CAB + CAB')'.
Edit: I was rushing the question so much and I finally realized what I was doing wrong thanks BvU for putting up with me it's 2am where I live and I'm clearly not in the right mind at the moment. Solved.
Yes. The NOT portion comes afterwards. (CA)' is easier to do than what you had before.
Great. Advice: go a bit slower :smile: The speed will come with experience; in the beginning taking small steps and doing it right are more important.
