- 4,230
So u can simplify the sqrt with the denominator and be left with a product.
Daniel.
Daniel.
dextercioby said:[tex]|x|=\left(\sqrt{|x|}\right)^{2}[/tex]
So,unless that "x" is 0,u could simplify.
Danie.
baby_garfield said:isn't it just 1?!
gregmead said:what does your equation do that the traditional lorenz transofrmation can't ?
master_coda said:It gives negative values when v > c instead of complex ones.
eNathan said:THANK YOU! It just seemed that people over here https://www.physicsforums.com/showthread.php?t=65446 could not get that (althoug half of it was my terrible latex formate). The reason why I like the equation is for theoretical v > c travel. My equation states that if you travel faster than light, "negative time" will have passed, hence you traveled into the past. I know relativity forbids it.
[itex][itex] <br /> I see your point. My equation probably does not describe anything physical, but I said "if I were to assume v > c = -t (backwards in time) then how in the world do I calculate it? Hence, I made the equation. I guess the traditional [tex]\sqrt {1-(v/c)^2}[/tex] would be "better" in the respect that it limits the equation to only v < c and v = c travel. I am fully aware that my equation does not abide by relativity, but it seemed that the "mathematical" aspect of my equation was in question, when in fact the equation works fine. Some tried to simply the v > c equation but they could not. For instance [itex][\sqrt{1-(\frac{c}{v})^{2}}]^{-1}[/itex] gives a positive result for v > c and a negative (imaginary) result for v < c. <br /> <br /> I assume all this is cleard up now. My equation works if you were to assume <br /> v > c means negative time (over infinite mass and negative length). But it would be best to keep the original LT because the theory of relativity forbids it.<br /> <br /> <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":smile:" title="Smile :smile:" data-smilie="1"data-shortname=":smile:" />[/itex][/itex]whozum said:eNathan, the reason people don't get your writing is because you don't get their explanations. Realize that most of the people really DO know what theyre talking about, as most of them are graduate students or above in physics. They have degrees in this kind of thing. When they tell you something, take it as correct.
What are your qualifications? Do you think something as trivial as an absolute value sign could answer our questions about time travel? If it was that easy, do you think Einstein wouldn't have come up with it? Any equation can be manipulated to do what you want it to, but that's not the point. The point is to find an equation that describes what happens.
I can say:
[itex]v = -d/t [/tex], so then [itex]-d = v*t [/tex] <br /> <br /> and claim "hey look, you can have negative distances!", but that equation no longer describes the physical phenomenon its intended to.[/itex][/itex]
whozum said:Your equation works but it has no meaning. You can't assume v>c means negative time when you are talking about your equation, it represents nothing in physical reality:
It is equivalent to
[tex]f(x) = \sqrt{1-\frac{x^2}{k}}[/tex]
Why would someone consider that function to have anything to do with reality, until he observes reality to follow that pattern? If they would, why not
[tex]f(x) = \frac{e^xsin(x)}{(x^3)(x^2-2x+e^xln(.47sin(x)))}[/tex]? I could say when ln(.47sin(x)) is larger than e^x then such and such happens, but there's no reason to say that the pattern of increase of those two functions will describe how something works.
You model equations to fit the world, not model the world to fit equations. I understnad your intent wasnt to model anything physical, but when you take a relatively (no pun intended) infamous equation and start manipulating it to do something you want, without changing the variables, you are implying that you are attempting to change that model (for that specific problem). If you had instead used
instead, you wouldn't have any arguments as to the validity of the equation for modeling purposes.
eNathan said:I think we are both on the same page here. Yes, my equation does not describe anything physical. But, if you look at a graph of time dilation, you can almost predict or assume (logical) that if v > c then -t. But I have not taken any courses on relativity (although I want to), and all of my studies are straight from the NET. And the NET has some very innacurate and misleading statements therein.
whozum said:You keep doing exactly what we tell you not to do. You are graphing a function that has a physical meaning, and then changing the function and trying to interpret the physical meaning of the new function. there's a reason the absolute value sign isn't in there.
IF
[tex]f(x) = \sqrt{|1-\frac{x^2}{k}|}[/tex] AND [tex]x^2 > k[/tex]
THEN [itex]f(x)[/itex] would be negative. This is 100% correct. Thsi is as far as you can take your problem without starting to **** with relativity theories.
I've given up on eNathan threads, if you look back I've already explained it all and where the confusion came from. What exactly if your issue? Perhaps you could start another thread with a problem you have.abia ubong said:hey zurtex i need more xplanations
