Engineering Simplying the circuit into Boolean expressions [2 Questions]
The discussion focuses on simplifying Boolean expressions for two homework questions. For Question 1, the user presents an expression involving multiplication and complements but is unsure how to simplify it further. Question 2 involves a more complex expression, and the user questions its correctness while seeking assistance. A suggestion is made to use truth tables to verify each step of the simplification process. The conversation emphasizes the importance of showing earlier work for better guidance and recommends addressing one question at a time for clarity.
lunapt
Question 1: http://imgur.com/Px0n152
Question 2: http://imgur.com/tZ0beF6
For Question 1, I got:
(AB.CD) + [(CD)' . (AB)'] with a "." = multiplication and ' = complement.
into (AB.CD) + [(CD+AB)']
I"m not sure how to simplify this further.
Question 2 is really long and I would appreciate help. I got:
A' + (D'+C') + A + (A' + C'+ D') + B' .D ' + (D+B)' = F
I'm not even sure if this is correct, and these two questions are due as homework tonight.
Any help would be much appreciated, thank you.
Hi lunapt. At any line in your working you yourself can check that you are proceeding correctly by drawing up a truth table for that line. Compare it with the truth table for the original logic, and they must agree at all times, right up to including your answer. :smile:
By not providing your earlier working, you don't allow us to identify whether the line you show has been arrived at correctly or not, or even whether it is your own effort. So can you show how you obtained that line?
Good luck! The simplified expression could not be much simpler. :approve:
BTW, it is best to present only one question, as it is likely that the help you receive with it will enable you to go on and solve other similar ones.
