Python How to Correctly Simulate an Infinite Well in Python?
This discussion focuses on simulating an infinite potential well using Python, specifically employing NumPy and SciPy libraries. The user encounters issues with eigenfunctions and eigenvalues not aligning with the expected analytical solutions. Key suggestions include verifying the matrix construction in the Laplacian function and considering the use of SciPy's linear algebra functions for improved accuracy. Additionally, the importance of ensuring proper normalization and matrix properties is emphasized.
  • Understanding of quantum mechanics concepts, specifically infinite potential wells
  • Proficiency in Python programming, particularly with NumPy and SciPy libraries
  • Familiarity with linear algebra, including eigenvalues and eigenfunctions
  • Knowledge of matrix operations and properties, especially symmetric matrices
  • Explore the use of SciPy's scipy.linalg.eigh for eigenvalue problems
  • Research the mathematical properties of the finite graph Laplacian
  • Learn about matrix normalization techniques in Python
  • Investigate the implications of matrix symmetry and positive semi-definiteness in quantum mechanics
Quantum physicists, computational scientists, and Python developers interested in numerical simulations of quantum systems, particularly those working with eigenvalue problems and matrix computations.
svletana
I'm trying to get the eigenfunctions and eigenvalues (energies) of an infinite well in Python, but I have a few things I can't seem to fix or don't understand...
Here's the code I have:
Python:
from numpy import *
from numpy.linalg import eigh
import matplotlib.pyplot as plt
from __future__ import division
def Laplacian(x):
    h = x[1]-x[0] # assume uniformly spaced points
    n = len(x)
    M = -2*identity(n,'d')
    for i in range(1,n):
           M[i,i-1] = M[i-1,i] = 1
    return M/h**2
L = 6
x = linspace(0, L, 100)
T = -0.5*Laplacian(x)
H = T
E,U = eigh(H)
n = 1 # change to see another state
plt.plot(x,U[:,n-1],'o')
plt.plot(x, sqrt(2/L)*sin(n*pi*x/L),'o')
plt.show()
First of all, the eigenfunctions U[:,i] appear to be normalized if I check, but they don't match the analytic solution. Also, the eigenvalues don't match the values of energy for the infinite well 0.5(πn/L)2.
What could I be missing? The math seems to be fine.
Would it make it better to use scipy.linalg instead of numpy's?
Thanks!
Technology news on Phys.org
Python:
def Laplacian(x):
    n = len(x)
    return M/h**2
Is that a typo in the next to last line? Should it instead be M[i, i-1] = M[i-1, i] + 1?
BTW, do you have a typo in your user name? svetlana is a name I've seen often, not svletana. If you've made a mistake, I can change it.
Likes svletana
Mark44 said:
Python:
def Laplacian(x):
    n = len(x)
    return M/h**2
The code should be
Python:
            M[i,i-1] = 1
            M[i-1,i] = 1
    return M/h**2
And my username is not a typo, I normally write it like this because svetlana is most likely taken :)
Now that I understand that part of your code, your two for loop versions do the same thing. What the loop seems to be doing is putting 1's on the diagonals next to the main diagonal of your identity matrix. The only thing that comes to mind that could be causing a problem is a possible off-by-one error. Keep in mind that range(1, n) consists of the numbers 1, 2, 3, ..., n-1, but doesn't include n. Make sure that your loop is setting all of the entries in the matrix that you want to have set.
Other than that, I don't see anything.
can you explain me what this part does?
Python:
            M[i,i-1] = 1
            M[i-1,i] = 1
I mean what is the array you produce?
I remember encountering a similar problem when doing this... Try to multiply the kinetic energy matrix T with some relatively large number, like 100, and see if the solutions then match the analytical ones (something like this worked, if I remember correctly).
A couple things:
it's preferable to use "import numpy as np" -- importing * is generally frowned on. (For instance if you use "sum" after importing *, are you using np.sum() or python's built in sum)?
Second, the (finite) graph Laplacian is well understood to be symmetric positive semi-definite with a minimum eigenvalue ##\lambda_n = 0##. That is ##\mathbf L \mathbf 1 = \lambda_n \mathbf 1 = \mathbf 0##, and since real symmetric, ##\mathbf 1^T \mathbf L = \lambda_n \mathbf 1^T = \mathbf 0^T##.
Just before your return statement in your Laplacian function, try adding the following two lines of code
Python:
ones_v = ones(M.shape[0])
print dot(ones_v,M)
# if importing numpy as np:
# ones_v = np.ones(M.shape[0])
# print np.dot(ones_v, M)
but this doesn't return the zero vector, which is very strong hint as to what's wrong here
--- alternatively, you could insert similar code just below your assignment to T. Either way the ones vector is not in the nullspace of your Laplacian which means it is not a Laplacian
  • · Replies 21 ·
