Simulation Code for Earth's Historical Temperature Record
optotinker
TL;DR
Earth Temperature Simulator
I am new to the field of climate change. Are there publicly available simulation code for Earth's temperature history, going back, say 2000 years, with a resolution on the order of years?
Thank you very much.
on Phys.org
optotinker said:
Summary:: Earth Temperature Simulator
It is extremely difficult to separate serious information from politics when it comes to climate change. I think a good way to search for the former is to look up the keyword Keeling curve. It started in 1958 but I assume that it has been calculated backward. E.g.
https://keelingcurve.ucsd.edu/permissions-and-data-sources/
Thanks.
I saw an old thread somewhat related to my question here:
https://www.physicsforums.com/threads/temperature-in-Earth's-history.631851/
I am looking for something more quantitative, i.e. a simulator that takes into account all factors that influences the temperature. With that, one can play "what if" scenarios.
Is the current consensus on global temperature solely based on various gases in the atmosphere?
It's easy to make simulations. But it can be difficult to verify that the model is accurate. With a lot of effort you may be able to show that the model would have predicted the known history, but how could you be confident that "what if" scenarios predicted are trustworthy?
What do you have at home, a Cray?
There are plenty of models that fall under your description, and little certainties for such a black and white view on the subject. Climate models require huge computing power and probably dozens of assumptions.
Have you looked on the websites of the major institutes across the globe? I assume that every industrial nation operates such an institute. Here are the homepages of two of them:
https://www.usgs.gov/
https://www.gfz-potsdam.de/en/home/
If you want to seriously examine the subject, then start to look for serious information. The Keeling curve is one such measure and the homepages above two serious institutes. If you find on the internet what you are looking for, then take it as a toy, not a serious simulation.
It is indeed a very good question. At this point I am only looking at tools and data. I like simulation because a good simulator should take into account all known effects. It has the ability to synthesize these effects in a way far beyond the ability of a human brain, and its references should contain the key literature for said effects.
And of course there is the issue of trustworthiness. But all scientific work face the same issue at some point.
In the old days, we got free code from Universities and used them for serious industrial applications. I am looking for something like this in this field. I would worry about computing capabilities later.
I want to get into the field as a player, not a spectator. The information offered by major institutions to the general public is helpful but it is already someone else's work, not mine.
I guess a certain hubris is required for every undertaking. All you need to model is the entire planet! But one step at a time.
The current system of great ocean currents alone is a significant part of such models, and there are hints that e.g. the Gulf Stream is already weakened. If it collapses, then all your data will be worthless. Similar is true for melting of the permafrost regions or a major outbreak of a hotspot. These are extreme examples that may or may not occur.
The more direct components involve dozens of feedback loops, chaos, and last but not least, our own behavior. ##CO_2## emissions are only one relevant parameter. It is the one we possibly could measure best and influence most. We have achieved a reasonable weather forecast of about a week, maybe two. But climate is the collection of all weather systems on earth, and over a period of years, not weeks. So if the weather is already unpredictable for next month, how could we rely on climate predictions?
There are many models, and most of them point in the same direction, which increases confidence. But none of them has been calculated in a browser environment. Java, HTML, and PHP are insufficient.
If you really want sound data, then look at who has to deal with it professionally! Study the balances (over the last decades) of our biggest reinsurance companies! Politicians may lie to us, climate models may predict slightly varying scenarios, but money is unaffected by all those. Maybe not really a scientific method, but at least a reliable one.
Firstly, I definitely don't want to touch on politics or insurance at all.
To the first order, the Earth is just a ball under the Sun. It takes in heat from the sun and radiates heat out into the 4K space. Do we really need to model the weather at each point on Earth in order to get a any idea about global temperature?
No, probably not. But you need to know the concentration and distribution of several atmospheric gases like e.g. methane and carbon dioxide in order to calculate what is reflected back into space and what is not, plus the amount of energy that is stored in oceans, storms, waves, or simply the atmosphere itself, plus the exchange between all of them, plus the conversion details of the gases from short to long wavelengths of sunlight, plus the albedo effect of human installations and global ice shields.
And this list is only my layman opinion. I'm sure that climate researchers have a longer list. It is not a simple in and out. And we are not only interested in the energy balance, but we also want to know the local consequences.
I don't want to be insulting, but that's just foolish. You should have more faith in the "Garbage in. Garbage out." philosophy.
optotinker said:
global temperature
Please define this.
It is not useful to discuss 60 year old physics unless Please let us not unless you know something new. I have done the simple calculations you should too. Then listen to Carl Sagan who knew the answers 40 years ago.
Well, it is a tool, with its pitfalls and advantages.
Vanadium 50 said:
Please define this.
It is what we call a "lumped parameter".
Exactly. That was my first thought as well.
You need to model each Butterfly, right? :wink:
  • Haha
I am looking for a simulator, not a Saint :)
Seriously these calculations are essentially at three levels of complexity. The simple radiative balance equations take a competent physicist a half hour to show the Earth should about around 0C(273K) . The next level, including rudimentary atmospheric effects, takes a day or two to work through and adds a few tens of degrees. The final level takes a lifetime of effort and produces the present best estimates which are proving more accurate than one might wish.
Incidentally Prof Sagan's doctoral thesis explained why Venus is 300C hotter than it should be because of radiant balance alone. He was smart, not Holy.
Thanks. Good to know.
It would be good to find something between "a day or two" to "lifetime".
We can all agree on that, including those in the midst of calculations.
Did you know a primary impetus for the first supercomputers was for weather forecasting? The atmospheric models were developed and they could do pretty good predictions but the computers took two days for tomorrow's forecast. Even senators could figure out that supercomputers would pay for themselves. ( The space program has similarly paid for itself many times over simply from weather forecasts)
Interesting.
I definitely don't want to get into the weather stuff. One will never get out of that rabbit hole.
Sorry, but you are not "a player" in this field as a one-man show. Get a degree and become part of a research group. Or, if you insist on being the lone ranger in your spare time, you have to build on existing literature and narrow your field of research a couple of orders of magnitude. Do a study of dendrochronology, or write a review, don't think you can simulate the whole freaking system with someone else's code and ten thousand dollars of computers alone.
Thank you for your suggestions.
But my understanding is that anyone can be a player in science, any science.
A player, in my definition, is someone who brings new insight into the field by acquiring and analyzing data and playing with models, first hand.
I have worked with many first rate scientists both in academia and in industry. One common feature of them, or rather us, is never to tell anyone "you can't do this". We help and encourage. It is up to him to decide if he can or cannot.
Is this field somewhat different? I am just looking for a tool. I am a bit surprised by the odd responses so far.
  • Skeptical
Not really. An amateur with little education and little experience and little understanding of the current peer-reviewed scientific literatature has little chance of being a "player" in changing the world. I'm not saying that is you, since I know very litte about your education and professional background. We have Insights articles about many aspects of what you are saying in the quote.
Which responses in particular? The response theme that you can't simulate the weather without computing resources comparable to multiple Cray computers?
If you wish to play with this stuff then more power to you. There is no better way to learn. But it is not out of line for folks with presumably broader knowledge to offer friendly advice about the difficulties you may face.
You will not paint like Rembrandt because you find some new brushes and a pantograph.
This field is critical for the survival of mankind, quite unlike stuffs like the string theory. It is only natural, therefore, for anyone to take an interest in this. There are many people like me, I believe.
Almost everyone these days "gets a degree, and work for some institutions". But real discoveries are often made by people with a fresh point of view and an original way of thinking, not by the 9-5 employees with degrees. I would especially like to hear more from the first group here. The employees, on the other hand, already have Nature to publish on.
But of course everyone should be welcomed to express his views, including myself.
  • Skeptical
Really? Name five. In the last fifty years.
Yes, and that is my greatest fear of all. That someone convinced he is smart invents something to change atmospheric mechanisms and make things worse. There are already horrible suggestions on the table.
We are talking about a system whose description requires hundreds of variables, dozens of differential equations, all with uncertain initial values, many depending on each other, uncounted assumptions, and that takes really huge computing power to solve. And now add a self-proclaimed genius who changes one crucial equation, or worse, adds another crucial equation. How are the odds that it improves such a system?
The survival of mankind is not going to be affected by one guy in his basement with a computer looking for who knows what. The science is sufficient as it stands to yield a direction.
If you wish to save the planet, the hard work is to motivate the naysayers and the troglodytes. Elect people with the knowledge and courage to act. This is a place where your energies and skills might well yield tangible fruit. Let's get busy.
  • · Replies 0 ·
  • · Replies 42 ·
9K
  • · Replies 28 ·
