Simultaneity: Train and Lightning Thought Experiment
136 replies · 16K views
Josh_Seedman said:
Can't we claim that these two clocks are in fact synchronized with each other, regardless of whichever inertial reference frame they both reside in?
No. Assuming the train has Born rigidity (it maintains its proper length in each momentary rest frame during its acceleration), then the clock at the front of the train will run faster than the clock at the back during the acceleration, and when acceleration ends, both clocks will again run at the same speed but will be out of sync in the train's rest frame. In the platform rest frame, both clocks would slow down as the train accelerates at the same rate and remain synchronized. This is due to the fact that the plane of simultaneity at each point on the train is shifting during acceleration, causing "now" for any point on the train ahead of the point of interest (in the direction of acceleration) to shift into the "future" from where it was, and causing "now" for any point behind the point of interest to shift into what was the past of where it was.
The most important fact to remember about the relativity of simultaneity is that if you have two clocks separated by some nonzero distance in space, then they can be synchronized in at most one valid inertial frame of reference. In all others they will not be.
Josh_Seedman said:
Well I guess I was thinking something like well before the lightning event, in fact how about well before the train started to move at all, the woman on the train synchronizes the two clocks with each other. That is, she verifies that the clocks are counting time at the same rate (again, within an acceptably small magnitude of error).
Two clocks at rest with respect to one another will tick at the same rate. That isn't a problem. The question is, how do you determine that they're showing the same time? That they've been zeroed correctly? It's easy enough to come up with some procedure for checking this (for example, seeing if the clocks appear to show the same time when you are half way between them), but when you follow through the details of any procedure you'll find that the answer to that question depends on the velocity of the person making the measurement.
Josh_Seedman said:
She then carries one clock to the front of the train, mounts it, and then walks the other clock to the back of the train and mounts it.
That's a valid way to synchronize the clocks. Now consider another train moving along a parallel track. A man on that train does the same thing with his clocks so they are also synchronized. When the two trains pass each other the woman can check to see if the man's clocks are synchronized, to her they won't be but to him they will. Likewise, the man can check to see if the woman's clocks are synchronized. To him they won't be, but to her they will.
I don't know, perhaps I am missing the point. I guess I would not be so concerned with what various observers might themselves observe.
Well, the woman observed that her clocks were synchronized, so being concerned about her observations is what got your thought experiment started.
The bit about the lightning strikes is just a teaching tool, used to demonstrate one of many different ways that you can synchronize clocks.
Josh_Seedman said:
I guess I would not be so concerned with what various observers might themselves observe. Instead, I would suggest that if the two clocks recorded the same time instant, that information would indicate that the lightning strikes were simultaneous, even if they did not appear to be simultaneous to the observer on the moving train.
It's not just a matter of what they observe; if it were we could write the whole thing off as an optical illusion and not worry about it. But the problem is deeper than that.
Suppose a star five light years away explodes. Eventually the light from the explosion reaches your eyes and you observe it. When did the star explode? The only sensible answer is "five years before the light reached your eyes" because it took five years for the light to travel from the explosion to your eyes.
We can push this idea a bit further: Suppose that there are two stars, one five light-years away and one eight light-years away. They both explode, and you observe the light from the nearer explosion at noon on 1 January 2012. Three years later, at noon on 1 January 2015, you observe the light from the more distant explosion. It is clear that both explosions happened at the same time, namely noon on 1 January 2007. It doesn't matter that you observed them at different times. Knowing when the light reached your eyes and how long it took to reach them let's you calculate when the explosions really happened, and in this case you correctly calculate that they happened at the same time. It also doesn't matter whether the stars were moving or not; all that matters is where they were at the moment that they blew up.
But the point of Einstein's train experiment is that someone who is moving relative to you will do the exact same analysis (take the time the light reached them; subtract out the time it took the light to get there; and they have the time that the light started out) and correctly calculate that the two explosions did not happen at the same time. Thus, we have to accept that "at the same time" is inherently frame-dependent.
Here’s my attempt at answering taenyfan’s very fine question on Einstein’s train experiment:
The problem defines two frames of reference moving with respect to one another. In the platform observer’s frame the two strikes are simultaneous. In this scenario the woman must be considered to be moving relative to the lightning strikes, specifically, toward the forward strike and away from the rear strike.
We could just as well consider the train to be “at rest” and the landscape, including the platform observer moving from the train’s front to its rear. In this case the woman will see the two strikes as simultaneous but the man — who is “moving” toward the back of the train and away from the front — will see the rear strike first.
Since the two frames are moving relatively you must pick one or the other when describing the two strikes as “simultaneous”. You can’t have it both ways.
This is "sensible" in the IF of the observer. For someone following the light from the explosion at near light speed, the answer is "almost instantly before the earther saw it" - of course he would synchronize Earth clocks with the exploding star's clock differently than the earther would.
Worded like this, there's a danger that it might make it seem like the same two strikes are simultaneous, for both observers, and which observer considers them to be simultaneous is a choice.
It's absolutely true that two strikes could occur that happen to be simultaneous for the train observer; but these two strikes can't be simultaneous for the platform observer, no matter what frame of reference is used.
(I'm sure that's what you meant, I was just worried about how the bit I bolded could be read by someone - that it's the same two strikes that the standard thought experiment stipulates are simultaneous in the embankment frame. I'd have worded it like "In this case the woman might see two other strikes as simultaneous but the man ...".)
That definition of when an observed event happened (time of observation minus light travel time to point of observation) works for all inertial observers - no other definition is "sensible" in the sense of being free of internal inconsistency. The point of the simultaneity thought experiment is that it produces different results for observers in motion relative to one another.
In more carefully crafted versions of this scenario the lightning strikes leave char marks on both the train car and the train tracks. Thus the woman on the train is always midway between the char marks on the train and the man on the platform is always midway between char marks on the track. It's the light that was emitted from the lightning strikes that arrive at the observers, not the strikes themselves.
All that matters is that one observer (in this case the woman, but in other versions it could be the man) sees one flash arrive before the other, but the other doesn't.
But you would have to create a different version of the scenario, as mentioned above, not simply change your consideration of who's at rest. In other words, if the flashes arrive at the man at the same time, that is a single event and as such it's invariant. The woman will agree that the flashes arrived at the man at the same time. And she will conclude that the reason that happened is that one of the flashes was emitted before the other.
Ok so it is sensible in a circular way I guess. "Light travel time" will be different for different observers. When I see a star explode on earth, in the IF which roughly contains the Earth and the star I will conclude the star is pretty consistently 4 LY away and light took 4 Y to get here.
However, if you're thinking about it that way you're setting yourself up for future confusion. When you say "the IF which roughly contains the Earth and the star", you seem to be suggesting that there might be an inertial frame (or non-inertial frame, for that matter) that does not "contain" the Earth and the star. That's not right, because everything is always in all frames always - there's no such thing as being in one frame and not another.
There is such a thing as being at rest in one frame and not another, but that doesn't change any of the physics. In particular, the basic principle that the time something happened is the time at which it could be observed minus the light travel time between the event and the point of observation works in all inertial frames. Whether the source or the observer is at rest in the frame is irrelevant.
I meant the IF in which the Earth and the star are basically at rest. In this frame, the star explodes and the time it takes for that light to reach Earth is 4 Y. In a different IF - traveling .999c, arriving at the star as it explodes, then passing the Earth - the time between explosion and seeing on Earth is miniscule.
As is the distance between the two events.
Yes, your meaning was clear from the context. That's usually referred to as the rest frame of those objects.
I think the point @Nugatory makes is that using the language one way signals an understanding, but using it another way signals, if not a misconception, then at least a warning that it might lead to a misconception.
And calculations done using that frame would also involve the delay due to light travel time.
OK. How about I back-peddle by a few steps and instead request the following assumption: The two clocks on the moving train are synchronized only after the train has reached its constant velocity. The sense I get is that it can be agreed that one or more valid procedures exist by which these two clocks can be synchronized to each other, in the IF of the moving train. Yes?
Yes, assuming you mean rest frame of the moving train when you say IF of the moving train.
But then they won't be synchronized in the rest frame of the platform. That's the point.
I found the thought experiment here http://www.bartleby.com/173/9.html
and Einstein concluded:" Events which are simultaneous with reference to the embankment are not simultaneous with respect to the train, and vice versa (relativity of simultaneity)."
Now let me place a long seesaw on the embankment and parallel with the railway. This seesaw is working. I mean its both ends A & B are moving up and down continuously.
Let us consider two events: A is at high position and B is at low position. According to the relativity of simultaneity, these two events are simultaneous with reference to the embankment but are not simultaneous with respect to the train. Hence, the woman on the train claims that the seesaw is not straight up but it is curved up and down on its both ends A & B continuously. The lady questions why the seesaw is not broken?
Rotating objects generally look rather odd in relativity - you can't have rigid objects, so it's not that the seesaw is broken but rather that it is not rigid. A related phenomenon is the appearance of a wheel at relativistic speed. Even if the wheel is not itself rotating relativistically then it is length contracted into an ellipse as seen from a moving frame, yet it still rotates.
An important point to bear in mind, which I forgot to mention above, is that the seesaw is not straight even in the embankment frame. When one end strikes the ground a mechanical wave propagates up the beam at the speed of sound in the material and the other end doesn't stop rising until that wave reaches it. That's typically on a timescale of milliseconds, which is why you don't notice, but it's always going to be flexing.
Relativity forces you to pay attention to such details. Unfortunately that means that a formal analysis of this problem requires a detailed mechanical model of the seesaw and its reaction to applied forces.
The problem is in the description of the situation, which states that the lightning strikes are "simultaneous" without stating that the simultaneity is from the man's (bystander's) point of view. Let's re-describe the problem from the woman's (passenger's) point of view.
A woman sits at the middle of a train. Out the window she sees the countryside - which includes a man standing watching the train - rushing by in the direction of the rear of the train. Suddenly she sees lightning strike the front and rear cars of the train simultaneously. The question is: What does the man see?
Since he is rushing toward the rear of the train, he sees the lightning strike the rear car first because, as the light travels toward him, he is traveling toward the source of the light. By the same token, he is moving away from the strike on the front car so it takes longer for the light to reach him.
Since we typically spend more time on the landscape than on trains, we naturally take the man's point of view when describing this apparent paradox. So as soon as you read the (biased) description you are already on the "wrong track".
It's also a question of by how much the seesaw is out of sync. In the frame of the train, clocks at either end of the seesaw will be out of sync by ##\frac{Lv}{c^2}##, where ##L## is the rest length of the seesaw and ##v## is the speed of the train. The train must be traveling at less than ##c##, so an upper limit on this is ##\frac{L}{c}##.
Now, for a seesaw of even ##100m##, say, this is a very small time difference, less than a micro-second. The woman on the train will still measure the seesaw as being essentially in sync and observe nothing unusual.
Note that the seesaw will be curved in the platform frame as well, due to the forces along its length.
We don't have to use a seesaw moving up and down. Let us use a horizontal seesaw that its two ends move closer and farther from the railway. I mean the horizontal seesaw rotates freely an small angle during the experiment.
You can imagine a horizontal seesaw. And the seesaw rotates an angle freely during the experiment.
I would tend to believe the conclusion that the see-saw is curved, as "rigid objects" simply aren't compatible with special relativity. One can define Born-rigid motions in special relativity, but objects satisfying the necessary criterion to be Born-rigid can't change their state of rotation. Your see-saw is changing it's state of rotation, so it can't be Born-rigid.
You may not be familiar with Born rigidity. I don't see how you can learn about it before you learn about the relativity of simultaneity, though. So the process of learning special relativity involves first realizing that simultaneity is relative, then exploring all the logical consequences of this fact (along with the other aspects of SR such as length contraction and time dilation, though the relativity of simultaneity seems to be the hardest thing for people to learn). The lack of rigid objects is one of the logical consequences of special relativity, I'm unsure if it can be formally deduced solely from the relativity of simultaneity however.
I don't think your exposition isn't quite complete, a drawing of the seesaw from the perspective of the ground and from the train using the Lorentz transform would be interesting. I believe your conclusion is probably right, but the argument isn't quite rock solid yet.
This doesn't change anything about any of the arguments already made. For the seesaw to swing back and forth on any axis, some force must be applied to it at some point, and that force cannot propagate through the seesaw faster than c.
Let me say the seesaw is rotating at a constant angular speed (like the Earth is spinning).
At the time point that the train is passing it, it is parallel with the railway (and is still rotating)
The seesaw will not appear straight. Also its length will vary as it rotates. You may wish to Google for "relativistic wheel" and look at the shapes of the spokes.
To build on Ibix's point, Let's consider the following two illustrations:
On the left we have our rotating pole (light blue bar), The tracks (black and brown lines), the train( green line) and our observers on the embankment and on the train (red circles), according to the embankment frame. This is the moment the observers pass each other. The pole is parallel to the tracks, and its ends line up with both the end of the train and particular points on the track (the white lines). The pole is rotating counter-clockwise as shown by the blue arrows.
One thing needs to be noted in this image, the train, since it is moving relative to this frame is length contracted. In other words, the length of the train as measured in this frame is shorter than the length of the train as measured in its own frame.
This becomes apparent when we look at the right image, which is drawn from the frame of the train. We are still dealing with the moment the two observers pass each other. In this frame the train measures its length as its proper length, while it measures the tracks and embankment, which is moving relative to it as being length contracted. As a result, the train no longer fits neatly between the white lines, but extends quite a bit beyond is both directions. This also means that one end ( the right end in this case) has already passed its white line before the other end hasn't reached its white line yet.
Also note that the bar appears as being curved, as per Ibex's post, and the right end of the pole has already gone past the point where it is adjacent to the tracks, while the left end has not yet reached that point. If this were an animation that we could run backwards and forwards, you would see the ends of the train lining up with a white line at the same moment that an end of the rod was adjacent to the same spot. This just happens at different times for each white line. Another thing to note here is that as the rod rotates in this frame, the curvature of the rod does not remain constant but changes from being curved as shown here to being straight when aligned vertically.
That is what I said: "the woman on the train claims that the seesaw is not straight up but it is curved up and down on its both ends A & B continuously. The lady questions why the seesaw is not broken?"
Just because the See-saw is curved in her frame does not mean that it is under stress in her frame.
In the following image we see the same diamond shape, in both its rest frame and according to a frame in which it is moving at 0.8c.
In the top image all the corner angles are 90 degrees, in the bottom image, one pair of corners is more than 90 degrees and the other pair is less than 90 degrees. But this does not mean that the shape is under some type of stress at the corner. Even if the shape was rotating, and thus constantly changing shape in the bottom frame, it would not be undergoing any stress.
