Sin wave Maximun/minimum finding?
  • Thread starter Thread starter pjunky
    Sin Wave
To determine whether a sine wave is at a maximum or minimum at specific points without knowing the y-values, one can analyze the function's derivatives. A maximum occurs when the first derivative is zero and the second derivative is negative, while a minimum occurs when the first derivative is zero and the second derivative is positive. The discussion emphasizes that for a sequence of x-values, one can infer the nature of the sine wave at those points based on the periodicity of the sine function. The user is seeking a method to identify maxima and minima based solely on the x-values provided. Understanding the area under the curve and the properties of sine may aid in this analysis.
pjunky
For different values of x in positive increasing order,sin wave would be either
Max or Min, so I plotted all points.how to find out whether wave is max or min
at a given particular point from X.
Thanks.
Can you describe the problem a bit better? It sounds like you have a sequence of values and some sort of sine function (Asin(w*t+b) as a function of t, A, b and w unknown) and want to know if you've hit a maximum. If that's what you're looking for, you can't do it
Thanks.
Well if you're thinking in terms of calculus, you don't need to graph this.
A function will have a relative maximum or minimum when its derivative is equal to zero (or at the endpoints of a piece of the function you're observing), and you can determine whether its a maximum or minimum by finding when its second derivative is equal to zero. When the second derivative is positive, the graph is concave up, and vice versa. A local maximum happens when you have the first derivative set to zero and the second derivative is negative. A local minimum happens when the first derivative is set to zero and the second derivative is positive. Beware, though, this is a general rule of thumb; there can be instances where the graph does not change concavity, or when a local minimum or maximum can be at the endpoint of such a piece of a function that you're looking at.
for Sin(0) wave is minimum,
for Sin(90) wave is maximum,
total:1,2,3,4,5,6,7...n-3,n-2,n-1,n
for Example assume at
1------->Max at x=1 ,y is max
2-------->Min at x=2,y is min
3------->Max
4------->min
5------->min
6------->min
n-1----->max at x=n-1,y is max
n------->min at x=n ,y is min
with out knowing y value,just with the help of 1,2,3,4...n how to know at a 3 or 4 or n-1
Y is max or min.
I got this clues,finding the 'area' bounded by the curve and with provided 1,2,3
finding out y is max or min at asked point.
please help me:rolleyes:,
Thanks.
3------->Max
4------->min
5------->min
6------->min
Y is max or min.
Thanks.
More clearly it would be like this
x=1,2,3,4,5,6,...n-2,n-1,n
for example
at x=1 sine wave is Maximum
at x=2 sine wave is Maximum
at x=3 sine wave is Min
at x=4 sine wave is Min
at x=5 sine wave is Maximum
at x=6 sine wave is Min
at x=7 sine wave is Maximum
at x=8 sine wave is Min
at x=9 sine wave is Min
at x=10 sine wave is Min
at x=n-1 sine wave is Min
at x=n sine wave is Max.
I mapped all the points,
so for x=1,how to find out wave is Max or Min
with out knowledge of wave.
I'm thinking like this finding out area bounded
by curve,and x values are given,so with the help
of 'area' and x values,I think I can find out y values(Max or Min)
Thanks.
If sin(1) and sin(2) are maxima, then sin(n) is a maximum for all n, as 1 is necessarily a period. I'm not sure what you're trying to get at
not like that you are taking sin(1),sin(2)...sin(n) as max
Just imagine x values in I quadrant in the graph.
now y values i.e sin wave values are mapped as min or max.
now have to find out at x=3 wave is max or min without reading the wave.
:confused:
10K
