Single slit diffraction - distance between 1st&2nd order dark fringes
6 replies · 9K views
louza8
Monochromatic light with wavelength 580nm passes through a single slit 2.60um wide and 2.10m from a screen.
Find the distance between the first- and second-order dark fringes on the screen.
y=(n*lamda*L)/d
y1=580nm*2.1m/2.1um=0.468m
y2=580nm*2.1m*2/2.1um=0.937m
y2-y1=0.468m
I am not sure how to handle the dark fringes in single slit diffraction, so I am not sure where I am going wrong.
Thanks for people's help in advance.
Do you know what the letters mean in the formula y=(n*lambda*L)/d and when is it a good approximation?
ehild
y is the distance between the fringes hitting the screen, n is the order, lambda is the wavelength, L is the distance to the screen, d is the width of the slit?
i don't know when it is a good approximation or what you mean by that.
Yo know a formula which contain the angle of deviation from the original direction of the light ray, hitting the slit. It is the exact one. ehild
n*lamda = d*sin(theta) ?
so would i use the angle found theta, and the known length L in a triangle to find the difference in y?
Yes. Calculate theta for n=1 and for n=2. The relation between L and y is y/L=tan(theta). If theta was very small, not more than a few degrees, you could approximate sin(theta) with tan(theta) and the equation in your first post would be valid. It is not the case now.
ehild
thanks ehild, helpful as always
