Singularities at end point in integration
The discussion focuses on the challenge of performing definite integrals involving singularities in MATLAB, specifically for the function sqrt((x-a)*(x-b)/((x-c)*(x-d))). The user seeks a MATLAB routine capable of handling such integrals, similar to the "dqawse.f" routine in quadpack, which is designed for functions with algebraico-logarithmic endpoint singularities. The user mentions that the gausscc.m file, which uses Chebyshev-Curtis quadrature, is inadequate for this purpose. Suggestions include using WolframAlpha for known parameters or approximating the function near the singularity with a simpler function for analytical integration, followed by numerical integration for the remaining parts.
ashesh
singularities at end point in integration...
Hi,
I Need to perform an integration with poles and zeros in the integrand. Please let me know if there a MATLAB routine/program that can handle the definite integral
between the limits (c,d), (a,d), (a,b) or (b,c).
I have read about the routine in quadpack called "dqawse.f" which can perform "integration of functions having algebraico-logarithmic end point singularities".
I need a MATLAB equivalent program that can perform this type of integration. I have checked gausscc.m file (http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=2905&objectType=file) which does integration by Chebychev-Curtis quadrature, but that seems to be no good in handling singularities.
Hope someone can give some leads to solve the above problem.
Thanks in advance.
Ashesh
I would use WoframAlpha if the parameters are known. If not, I'm not aware of a general solution to it, except perhaps a Taylor expansion.
Here's a simple approach:
Approximate the function by a simpler function at the singularity, which you can integrate analytically.
Integrate the singularity. Then integrate all the rest with your favorite numerical method.
20K
